AMSOIL
Old Nov 15, 2007 | 11:56 PM
  #21
tdmopar59's Avatar
tdmopar59
Default RE: AMSOIL
now for those of you who do it every 5k miles do you change oil and filter every 5 or change the filter at 3...
Old Nov 16, 2007 | 09:17 AM
  #22
drhunter's Avatar
drhunter
Default RE: AMSOIL
I just switched to Amsoil a few weeks ago and plan on changing every 15k unless the oil goes bad. Its rated to go I think 1 year and/or20 or 25k under light driving condions and 15k under heavy (I drive in light conditions). I bought their oil filter that is suppose to go just as far as well.
So far I've only put 500 miles on it after the switch but I plan on checking it often. I cant see spending around $70 with shipping to change the oil every 3k. I aint that rich. If the oil will not last as long as stated then I have been lied toand simply will not get it anymore.
I may change it out at 10k since this is the first time using it to see how it has held up.
Old Nov 16, 2007 | 09:40 AM
  #23
tboughton's Avatar
tboughton
Default RE: AMSOIL
Does anyone use Royal Purple and if you do how is it? I see they claim increased HP and fuel mileage and I can buy it off the shelf.
Old Nov 16, 2007 | 10:11 AM
  #24
tdmopar59's Avatar
tdmopar59
Default RE: AMSOIL
ORIGINAL: tboughton
some people like it... in all the experiences of my friends and a few people on this site it thins out way to quick!
Old Nov 16, 2007 | 11:37 AM
  #25
Drew's Avatar
Drew
Default RE: AMSOIL
royal purple is not a true full synthetic. . .it is a hydrocracked synthetic. . .just like mobil 1, however it is the addatives used that I would rather use mobil 1 over royal purple. Yet I'm an amsoil man myself. . .got 10K on my current oil w/ bypass filter and things are still going good. . .but I guess I can do that when Ive got 3 gallons to use instead of 5-6 quarts or what ever the hemi takes
Old Nov 16, 2007 | 12:40 PM
  #26
tdmopar59's Avatar
tdmopar59
Default RE: AMSOIL
hey hey hey we take 7 !!! lol
Old Nov 16, 2007 | 01:32 PM
  #27
Heminator2's Avatar
Heminator2
Default RE: AMSOIL
The highest milage vehicle I have owned, using Amsoil on a 7,500 change, was 512,060, yes, thats over a half million miles on a 1986 Dodge Lancer with the 2.5 4 cyl turbo charged engine. I did valves and valve seats one time, and the timing belt every 50,000 miles. Replace one A/C compressor, and thats about it. My 99 Ram 360 has 206,000 on it, nothing but Amsoil, and it runs like new.
I put the dual filtration on our 05 Hemi when it was new and have changed oil twice. I run it for 25,000 and change oil and both filters. Function speaks for itself.
Old Nov 16, 2007 | 01:55 PM
  #28
JD1500's Avatar
JD1500
Default RE: AMSOIL
Dr Hunter
If you have just changed over i would change it over at five, and then push it out from there. I change my amsoil every 5-6, but know a ton of people that use it for 10k.
to those of you that have added an additional filter, bypass i guess? How did you do this on a hemi motor. i am interested.
Old Nov 16, 2007 | 01:58 PM
  #29
Drew's Avatar
Drew
Default RE: AMSOIL
I'm not completely sure on the hemi motor, however there should be a tap at the primary filter mount that you hook to in order to hook up the bypass.
then you have two options. . .either drill a hole in the oil pan for the return, of get the filler cap and have the fresh oil from the bypass filter go straight to the valves.
Old Nov 16, 2007 | 04:19 PM
  #30
drhunter's Avatar
drhunter
Default RE: AMSOIL
ORIGINAL: JD1500
Dr Hunter
Yea I know having it mixed with what little oil was left in there would shorten the life of it but not a whole lot. I got the information belowoff the amsoil website. I dont run my truck off-road much, Idont take a million short trips, and I dont drive it hard so technically according to the makers of Amsoil I should be able to run it for 1 year or 25k whichever comes first under Normal Service. Seeing that I just switched over I more or less planned to change it at 10k. I really dont think I'm pushing the limit considering how long the oil should last. I will check it often though believe me and will get it tested at 5k probably. I aint taking chances. I will see if this stuff reallly does what it claims to do.
SERVICE LIFE
AMSOIL Synthetic 5W-30 Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first.
• Severe Service(4) – Up to 15,000 miles or one year, whichever comes first.
• Replace AMSOIL Ea oil filter at the time of oil change up to 25,000 miles or one year, whichever comes first (other brands at standard OEM* intervals).
• In all non-gasoline fueled vehicle applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval.
