Power steering failed. Now what?
Old Nov 12, 2007 | 11:13 PM
homer_simps1's Avatar
homer_simps1
Default Power steering failed. Now what?
I have a 2003 Dodge Ram 1500 (Hemi) and the darn power steering gave out and wouldn't you know it, the warranty has already expired.
Back story: I was driving on the freeway and the power steering gave out then the truck started running hot. I managed to make it cooler by turning on the heater and made it home.
So does anyone know how much it costs to get the power steering unit fixed from the dealership? Or are there any reputible Dodge mechanics in the Pomona California area?
I am not mechanically enclined so self-repair is not an option.
Thanks in advance for your help!
Old Nov 12, 2007 | 11:15 PM
tdmopar59's Avatar
tdmopar59
Default RE: Power steering failed. Now what?
are you sure its a pump and not a line?
Old Nov 12, 2007 | 11:21 PM
sddunn2's Avatar
sddunn2
Sounds like you blew a belt if it is overheating and you dont have ps check to make sure your belt is intact
keep us updated
Old Nov 13, 2007 | 01:00 AM
abarmby's Avatar
abarmby
sddunn2+1 It does sound like a belt???
Old Nov 13, 2007 | 07:52 AM
HuntinHanson's Avatar
HuntinHanson
yah i was thinking belt myself, did you look to see if it was still on?
Old Nov 13, 2007 | 08:15 AM
stratusguy02's Avatar
stratusguy02
I'm not buying the belt, if the water pump stopped the flow would not make it to the heater core. Homer may have just hit some **** luck. Was it hot or coldout when this happened? Have you driven the truck since?
Also, TD is on to something, do you have a puddle/spray under your truck? Is there still fluid in the reservoir? There is a P/S cooler right, check to make sure it is fine too.
Old Nov 13, 2007 | 08:46 AM
Pappy_FB's Avatar
Pappy_FB
+1 more for the belt.
I'm gonna jump on the Belt band wagon as well.
Easy to check
Old Nov 13, 2007 | 09:21 AM
tdmopar59's Avatar
tdmopar59
well here is my suggestion after reading the others suggestions bc i didnt even think of the belt (way to make me look bad guys ) check the belt it is cheap and easy to fix.... than check your lines once again cheap and easy.... the pumps require more work and money and are less likely to be the problem.. i have been through many instances working on other peoples cars where they thought they lost their power steering but it was just a bad hose or something......
Old Nov 13, 2007 | 11:23 PM
homer_simps1
Well the power steering fluid has been leaking for some time. All I had been doing was refilling it. I should've taken it to the dealership. That's what I get for being lazy.
The conditions were hot at the time I had these problems, but I don't think enough to make it run hot. I'll go run out to see if it is the belt and write back.
Old Nov 13, 2007 | 11:34 PM
sddunn2's Avatar
sddunn2
well ya got me curious !! fill us in when you find out
