Premium Amp location in 2008 Mega Cab
Old 11-20-2007, 02:24 AM
bplatek's Avatar
bplatek
bplatek is offline
Default Premium Amp location in 2008 Mega Cab
I tried to find out if anyone has replaced the rear speakers in a Mega Cab with the Premium Infinity. What size were they, and what fits?
also, where is the amp for this system in a Mega Cab (behind the glove box) and how much power does the factory premium amp put out.
is it 66 watts per channel x 2 channels?
Anyone swap out the factory amp with a Kicker 77kick18? How did it sound?
Bob
Old 11-20-2007, 02:26 AM
bplatek's Avatar
bplatek
bplatek is offline
Default RE: Premium Amp location in 2008 Mega Cab
I meant to ask if someone with the Premium Infinity has replaced the rears in a MC with something else? Ans what the amp power is for the premium and where is it?
Old 11-24-2007, 01:29 AM
bplatek's Avatar
bplatek
bplatek is offline
Default Premium Amp 2008 Mega Cab Help!!!
Does anyone know where the amp is? I have looked through the 2006 manual and cannot find it. Need Help...
Old 11-24-2007, 10:38 AM
Parts/Service's Avatar
Parts/Service
Parts/Service is offline
Default RE: Premium Amp 2008 Mega Cab Help!!!
DESCRIPTION
The optional Infinity premium speaker system includes a separate Infinity audio power amplifier. The amplifier is an eight-channel unit rated at 368 total output watts. The amplifier is located behind the glove box. If equipped, an additional amplifier rated at 140 watts is located under the center passenger seat.
INSTRUMENT PANEL MOUNTED
1.
Disconnect and isolate the battery negative cable.
2.
Remove glove box.
3.
Remove instrument panel center bezel .
4.
Disconnect electrical harness connector (4) from amplifier (2)
5.
Remove mounting bolts (3) and amplifier.
CENTER SEAT MOUNTED
1.
2.
Raise center seat cushion to access amplifier.
3.
Remove mounting fasteners.
4.
Disconnect electrical harness connector and remove amplifier.
Old 11-25-2007, 01:31 AM
bplatek's Avatar
bplatek
bplatek is offline
When you say optional, does that mean that even though I have the Infinity 7 speaker Premium system withNav, I still might not have this amp? That might explain why the system sounds so muddy and distorted (along with the fact that the speakers are OEM crap).
I guess I'll be dropping the glove box tomorrow to see if I have this gem!
Thanks for the info. Bob
Old 04-20-2018, 02:11 PM
2006Ram3500's Avatar
2006Ram3500
2006Ram3500 is offline
Default Infinity AMP Removal - Need Help
2006 Ram Dually Diesel with Infinity Sound System.
I cannot remove the infinity amp with only the "Instrument Panel (radio) Center Bezel" removed.
My Service Manual CD page 8A-154 shows the same schematic as Parts/Service but
says to also remove the "Lower Right Center Bezel". There is no such part described
on page 23-138.
Before I buy the replacement HVOC Recirculation Door / Panel, I need to be able to
remove the infinity amp to install it. I was able to remove the broken door through the
blower and now get a blend of both outside and inside air. This suits me just fine for now..
Old 04-23-2018, 09:06 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
If you have the Infinity system you have the amp. Pull out your glovebox, you'll see it right there. The one screw bolt is a bitch to get to though, hope you have small hands lol.
Old 04-25-2018, 09:24 AM
2006Ram3500
Thank you HemiLonestar.
I saw the infinity amp when I removed the glovebox
to locate the HVAC recirculation door motor / actuator.
I do not have small hands and posted if there was
an easier way to remove the amp without removing
the entire dashboard.
Years ago,when I installed the OEM Clarion navigation
(original radio had the infinity setup), I didn't have to
touch the amp. Everything was a plug and play.
I'll will have another look through the glovebox.
Thanks.
Quick Reply: Premium Amp location in 2008 Mega Cab
