Latest Oil Change
Old Nov 24, 2007 | 11:04 PM
DodgeRamRulez's Avatar
DodgeRamRulez
Default Latest Oil Change
Hope one of you guys has an answer for this. Had my oil Changed today and when my tech removed the filler cap for my lube, the inside of the cap looked like it had some rust and moisture on the inside. Should I panic yet? He said he thinks I'm missing a breather cap.
[IMG]local://upfiles/78343/303F31DF625C45F0B43E51C34E3EF524.jpg[/IMG]
Old Nov 24, 2007 | 11:17 PM
spud11's Avatar
spud11
Default RE: Latest Oil Change
Mine looks the exact same way. My grandfathers a mechanic by trade and he has never said anything about it when I have changed the oil.
Old Nov 25, 2007 | 02:45 AM
JD1500's Avatar
JD1500
I had this same problem my last change, concensus on here was that it was no problem. Asked the mechanic and he said the same thing, although gave me the reason for it wich i cant remember.
Old Nov 25, 2007 | 07:54 AM
LoFlyer's Avatar
LoFlyer
no problem, they all have it.
Old Nov 25, 2007 | 09:10 AM
DodgeRamRulez
Thanks guys I feel better now. This is my first Hemi and don't need any problems.
Old Nov 25, 2007 | 09:59 AM
sddunn2's Avatar
sddunn2
it is cause by short drives . the engine does not get a chance to warm up and burn up the moisture that is in the oil . hence the reason for a good long drive from time to time .
Old Nov 25, 2007 | 03:11 PM
OldMoparMan's Avatar
OldMoparMan
+1
The engine is metal. COld metal.... as the engine warms, condensation forms, and hot air rises. It's not uncommon, but as stated: If you don't run it long enough to get things dried out, then it sits there. Ford had an issue with that in the mid 80's with this on the 302's to the point that tan, yucky crap would be seen in the valve cover with the oil fill cap. It was harmless, but looked really nasty.
Old Nov 25, 2007 | 03:54 PM
NYPANAMA42's Avatar
NYPANAMA42
duplicate
NYPANAMA42's Avatar
NYPANAMA42
ORIGINAL: DodgeRamRulez
No fear, it's normal.. When i first got my vehicle, I started using Mobil 1 synthetic, and when i changed the oil myself, i noticed this tan/brown mayonaise type material on the underside of the oil filler cap...Checked it out with Mobil 1 and with a couple of people on this forum, as well as my trusted gooroo mechanic, and it's my understanding that i wasn't allowing the vehicle to run long enough, to burn off some of the condensation that builds up inside an engine.....So have no fear dude.....just keep driving, and keep changing that oil.....hope this helps..
Old Nov 25, 2007 | 07:51 PM
JD1500's Avatar
JD1500
At least i know why now. I never saw this in 25k miles on my truck. then just saw it last oil change. May have to do with that fact that i drive 5 miles to work instead of 40 huh
