CB question??
Old Nov 26, 2007 | 11:09 AM
pimpd1!'s Avatar
pimpd1!
Default CB question??
Ok so I have a CBI was planning on installing in my 04 Ram. I have 5% tint all the way around my truck and a few people I have talked to have said that the antenna wont read through the tint. The antenna I have in not a magnetic one....It looks just like a longer cellular phone antenna and mount to the outside window and the cable andothe half of the transmitter are on the inside.
So my question from anyone that does have one like this or any that knows about it......WILL THE ANTENNA BE ABLE TO READ THROUGH THE TINT/GLASS?? I really want to install this, but I dont want to waste my time if its not going to read/send a signal through the glass/tint.
Any help would be awesome.
Thanks
Old Nov 26, 2007 | 11:16 AM
spud11's Avatar
spud11
Default RE: CB question??
I don't know if it will read, but you will get almost nothing on the way of transmission power output. You'll be able to hear people but chances are you won't be heard by them unless they're on top of you. the best place for an antenna is on the roof of the truck, wilson makes a short roof mount, can't remeber the model number right now. I have a wilson 500 with the 6' whip and its the best I've ever had, looking to upgradeto the 1000.
Old Nov 26, 2007 | 11:51 AM
pimpd1!'s Avatar
pimpd1!
Damn it....I wonder if I cut a small square out of the tint behind the transmitter if that will allow it to go through, since you wont be able to see it anyways, because the transmitter box will cover that area. I am really trying to avoid using a magnetic antenna...i love the clean look/ as if it belongs there look of things on my vehicles and this is no exception.
Old Nov 26, 2007 | 01:58 PM
pimpd1!'s Avatar
pimpd1!
BUMP.....anyone else have some input....the more the merrier!!
Old Nov 26, 2007 | 02:14 PM
Tommygunz's Avatar
Tommygunz
Check this out, this is the one I used... It is for a full size (4',6' or bigger) antenna and mounts flush.. look s great in my opinion, plus you can ground the antenna unlike your standard chepo glass mount:
http://www.walcottcb.com/product_inf...roducts_id=308
Check out my gallery to see how it looks installed...
Hope this helps
Old Nov 26, 2007 | 02:52 PM
pimpd1!'s Avatar
pimpd1!
Thats not bad...im just trying to have something that looks like it belongs there......like the new vehicles (not the trucks) but cars that have the antenna that looks like it already comes on it....thats the look im going for.............
UGH......why cant they make one that goes through tint..LOL
Old Nov 26, 2007 | 02:54 PM
Parts/Service's Avatar
Parts/Service
I had an antenna mounted on 23% tint. I could barely talk or hear unless I was real close. I cut a square out of the tint and it helped some, but I ended up mounting an outside antenna.
Old Nov 26, 2007 | 03:15 PM
pimpd1!'s Avatar
pimpd1!
Damn....thats what I was afraid of..........ugh...well now it looks like Im going to have to do some thinking on this to see which route I wanna go.
More input is appreciated.....thanks again guys!!
Old Nov 26, 2007 | 03:20 PM
CarGuyOhio's Avatar
CarGuyOhio
If you want to get any range you will need a antenna outside, the bigger the better. It is a BIG RAM, the Antenna will be fine.
How about a roll bar, with 4-5 lights and two antenna on each side.... Expensive solution for antennas but it would lookand work good
10-4
Old Nov 26, 2007 | 03:58 PM
Tommygunz's Avatar
Tommygunz
ORIGINAL: 94rt10ohio
10-4<<<<
nice.... over
