View Poll Results: A poll
Amsoil
11.92%
Royal Purple
9.84%
Penzoil
5.70%
Valvoline
6.22%
Redline
0.52%
Quaker State
2.07%
Mobil 1
43.52%
Castrol
7.25%
Conventional
6.22%
Other
6.74%
Voters: 193. You may not vote on this poll
Oil
Old Nov 30, 2007 | 03:19 PM
tdmopar59's Avatar
tdmopar59
Default Oil
This is for what oil you reccomend/use...
The choices below are synthetics if you use conventional click that.....
Hemi before mds 5w-30
with mds 5w-20
also for filters either wix, amsoil, or mobil 1 they came back with the best test results in past posts......
Old Nov 30, 2007 | 03:23 PM
chongo's Avatar
chongo
Default RE: Oil
I am running Mobil 1 synthetic Extended Performance - rated for 15K or 1 year - will change at 7500 miles.
Also using a Mobil 1 filter. - Once I regear I will be using Mobil 1 synth. in the axles as well.
I would be using Amsoil - but I didn't like the fact that it wasn't as readily available. - That was the determining factor for me.
Old Nov 30, 2007 | 03:30 PM
Tommygunz's Avatar
Tommygunz
Default RE: Oil
I run Amsoil Diesel Engine Oil as well as Amsoil absolute efficiency filters, rated at 24,000 miles or one year although until I get to higher mielages and the engine is more broken in I will be changing every 10k...
Amsoil is only difficult to get your hands on when you don't know a dealer..
Old Nov 30, 2007 | 03:36 PM
tdmopar59's Avatar
tdmopar59
Default RE: Oil
I use amsoil and love it... started that after mobil 1.... i am a member so i just order that way...
Old Nov 30, 2007 | 03:37 PM
JD1500's Avatar
JD1500
Default RE: Oil
I run Amsoil 5-20 and a NAPA Gold Filter (black sticker over a WIX)
Actually, come to think of it, besides the trany's i run amsoil in everything My truck, and the GF's Neon. Motor and Diff's
Old Nov 30, 2007 | 03:55 PM
The Peddler's Avatar
The Peddler
Default RE: Oil
Mobil 1
Old Nov 30, 2007 | 04:28 PM
TANKZ400's Avatar
TANKZ400
Default RE: Oil
My first oil change I switched to amsoil and i hade to use mobil one because I could not find any amsoil, but i will be ordering a case asap. of amsoil
Old Nov 30, 2007 | 05:29 PM
drhunter's Avatar
drhunter
Default RE: Oil
I just put in amsoil recently but will probably switch to mobile 1 just because I can get it at walmart and dont have to pay for shipping.
Old Nov 30, 2007 | 06:07 PM
casper3380's Avatar
casper3380
Default RE: Oil
She hasnt had her second oil change, but it will be to mobil 1 synthetic, still debating on the filter.
Old Nov 30, 2007 | 08:00 PM
JD1500's Avatar
JD1500
Default RE: Oil
ORIGINAL: casper3380
Well for god sakes dont use a Fram
