Dash disassembly for 2007 center console truck
RE: Dash disassembly for 2007 center console truck
ORIGINAL: wmichell227
Are you referring to an aftermarket GPS unit? I just got a garmin nuvi and found its too far away to reach to answer the bluetooth phone. Please post pix after you get iyt installed.
Thanks!
Thanks!
[IMG]local://upfiles/32260/02ECA4064E5541D0B0938E0071561AAF.jpg[/IMG]
[IMG]local://upfiles/32260/46091FF4BDDB4F9596D07D232C03D24C.jpg[/IMG]
A quick update for those of us with 6-spds...
The console comes apart very similar to the way this one did.
1) Pop out the rubber cupholders, and the black cap for what appears to be a manual transfer case lever, if I had one.
2) 3 8mm screws, 1 under the plastic cap (towards the back, the one you can see at first is easier to get at after this comes off), 2 under the rubber insert.
3) the back section of the console, behind the shifter, should now pop out. Theres a clip towards the front that might be stubborn, mine was.
4) 2 more 8mm bolts to remove the shifter cover. I just pulled it towards the top of the shifter and put the shifter in 4th to keep this panel out of the way, rather than remove the shift ****.
The rest of it is the same as Stratusguy's walkthrough starting at the second post (with the trim piece at the bottom, or behind the shifter in our case).
ORIGINAL: mn12sc35gh
