Leveling kit
Old Dec 11, 2007 | 11:47 PM
SkullHD96CI's Avatar
SkullHD96CI
Default RE: Leveling kit
what year is yours. Will they fit 05 , what's the cost.
Old Dec 11, 2007 | 11:54 PM
kx250frider617's Avatar
kx250frider617
mines a 03 pretty much the same thing. there $85 each.
Old Dec 11, 2007 | 11:55 PM
kx250frider617
do u happen to have the foglights
Old Dec 12, 2007 | 01:17 AM
SkullHD96CI
yeah. Laramie pkg
Old Dec 12, 2007 | 10:12 AM
kx250frider617
k becuSE you'll want to drive with both on becuase the headlights will now point up a little so the foglights will kinda of bring light down. Unless you adjust ur headlights.
Old Dec 12, 2007 | 12:57 PM
moparman2k2's Avatar
moparman2k2
i got flashed all the time until I adjusted the lights down
Old Dec 12, 2007 | 01:55 PM
HammerZ71's Avatar
HammerZ71
Put the truck on a level surface, measure the distance from the top of the tire to the top of the wheel well on both sides. Jack it up so the tires are just off the ground. Crank the bolts a few times, then lower the truck to see where you are at. You may have to raise/lower the truck a couple of times. Shoot for 2" of lift, there the truck would be perfectly level and don't be surprised if one side needs to be cranked more than the other for the same 2". If you keep it at 2" and no more, your ride won't be quite as harsh as if you tried to take it higher. You also may be able to get by a while on the stock shocks at that height.
Get an alignment done ASAP and you are home free...
Old Dec 12, 2007 | 04:26 PM
kx250frider617
When i get flashed i show them my real brights haha i know its bad
How do you adjust them
