no taillights
well I am just running a good old house wire from one lead to another. I can't afford to bring it to the dealership since they will give it to me good and I don't want to waste my money. I also cant be without my truck for more than a day.
How much work would it be to change the fusebox am I best off taking it to the dealer?
i had the same problem i was under the impression that the circut for the tail/stop was the same for the trailer after tearing in to my wiring harness and finding nothing wrong i finally looked in the manuel and found out that there is a seperate fuesd circut for the trailer wiring and the ten amp fuse was blown. my other truck was pre 1992 a lot has changed
i'm having a very similar problem in my dodge dakota 98. the tail lights and license plate lights are out, head lamps and front parking lights are on... its weird, switched out bulbs, same issue. is there a wiring diagram you guys could forward me?? Thanks
i'm having a very similar problem in my dodge dakota 98. the tail lights (brakes lights work) and license plate lights are out, head lamps and front parking lights are on... its weird, switched out bulbs, same issue. is there a wiring diagram you guys could forward me?? Thanks
I have a 2002 Quad Cab 1500 4x4 with this problem. I have been reading and realized that the fuse box is my problem. Is there anyway to clean the box to get rid of the corrosion? I read that there is a card that corrodes. Is there anyway to get to this area of the box, or do I just have to buy a new fuse box? Please help. I miss driving my truck. I can only drive it during the day.
Do any of you Fella's live in Connecticut because I've talked to 2 guys here, and it seems like all of us with the same problems purchased our Rams up here....Just wondering thats all.
OK I Googled myself to death trying to find a replacement engine comp fuse box. 97 5.2 SLT. I have the no rear parking lights but all trailer lights work. So I need (as posted) the engine fuse block. Can anyone tell me where to get one? I am thinking New because of the problems with the used ones corroding.
