superchargers/turbochargers
Old Jan 23, 2008 | 01:37 AM
XxSilentHawk99xX's Avatar
XxSilentHawk99xX
Default superchargers/turbochargers
I know this may sound extremely stupid, but to all my fellow 3.7L owners, have any of you all thought about supercharging or turbocharging ur engines to boost up some more power to the ground? I want to see if there is ANY company out there that could make a supercharger for our smaller engines...Does anyone happen to know if there is such a company?
Old Jan 23, 2008 | 09:51 AM
Big#44's Avatar
Big#44
Default RE: superchargers/turbochargers
its been brought up before. i havent seen a company that makes one specifically for our truck, but there was one company that made a universal system or something. and im sure you could talk to a local shop and they could probably make you one custom, but its not going to be cheap.
Old Jan 23, 2008 | 09:11 PM
bobbyjoe101's Avatar
bobbyjoe101
they make an sts turbo kit i think
but i am not quite sure
Old Jan 23, 2008 | 11:36 PM
marv02's Avatar
marv02
Looked It to it already It's not worth it the Turbo kit from STS is $5000.00 Then you have to find someone to redo you Computer System good luck on that a lone you have to put new pistons and ringsin the motor the stock one will not hold up.
And as long as you are in the Motor mite as well do it right balance it nut to nut put some good Rods good rod bolts to handle the RPM's, Long skirt pistons,Good crank bolts bolts for the added power and RPM's, in it Ect more money.
Oh yea you also could have the heads ported bigger vavles.
Kenny Bell made a Super Charger Kit for the 3.7 but they pulled it off the market #1 didn"t sell enought of Them and #2 the motors were breaking down pistons were breaking at the Ring Land area not enough meat in the area for that much pressure.
And now will the trans hold up after all that work, More money and time.
Old Jan 24, 2008 | 01:39 AM
XxSilentHawk99xX
yeah i figured as much...if the STS turbo kit is 5000, I'd be better off just swapping engines up to a 5.7L hemi...
Old Jan 24, 2008 | 08:09 AM
marv02's Avatar
marv02
Well as I look at it you be better off trading it for anouther truck.
The $5000.00 is just for the turbo kit add anouther $3000.00 for the engine mods machining, And getting the computer set up.
Old Jan 26, 2008 | 04:22 AM
XxSilentHawk99xX
i could trade it...but i mean...all id really have to do is swap engines..for the most part the only difference is the amount of cylinders is it not?...I think the tranny is the same?
Old Jan 26, 2008 | 11:17 AM
marv02's Avatar
marv02
If you do a engine swap let's us know how it works out for you and the cost.
Good Luck.
ORIGINAL: XxSilentHawk99xX
Old Jan 30, 2008 | 05:24 PM
bobbyjoe101
yeah i was really thinkin about going with a sts turbo but once i saw all that
ha no way
but now i see that i can go to a junk yard get like a damaged 06 daytona engine for like 2k
but will my tranny be the same
and if not what would it be if
cause i got the 6spd and i want to stay standard lol (cant stand automatic)
Old Jan 30, 2008 | 09:23 PM
oefootball_70's Avatar
oefootball_70
you will need the computer from the dakota new everything, new tranny. Its not worth it to do the swap, you would be better blowing up the 3.7 and dropping a chevy 350 in it.
