SeaFoam
Old Jan 27, 2008 | 09:14 AM
bobbylight's Avatar
bobbylight
Default SeaFoam
i am about to use seafoam and i was just wondering how to get the brake booster line off of the brake booser? does it just pull straight out from the booster?
Old Jan 27, 2008 | 01:28 PM
MikeHTally's Avatar
MikeHTally
Default RE: SeaFoam
Well, straightdown.Takes some tuggin', too. You're taking the hose off the coupling. I was afraid I was gonna break somethin'. You can just pour the stuff into the hose while someone keeps it running for you. Follow the directions. As the label says, the "...fumes are intense..."
Old Jan 27, 2008 | 02:22 PM
bobbylight's Avatar
bobbylight
Default RE: SeaFoam
I just did it and it idles perfectly smooth! It also seems to run a little better.
The engine light came on though and my truck is throwing a P0300 code.
Will this go away?
Old Jan 27, 2008 | 02:24 PM
bobbylight's Avatar
bobbylight
Default RE: SeaFoam
This is what the code means but i dont know how to get the light to go off:
P0300 Random/Multiple Cylinder Misfire Detected
Old Jan 27, 2008 | 02:26 PM
abarmby's Avatar
abarmby
Default RE: SeaFoam
Code P0300 is a "engine missfire detected".
Might be a plug fouling or spark not igniting the mix, due to the fumes/seafoam?
Al.
Old Jan 27, 2008 | 03:29 PM
John  M's Avatar
John M
Default RE: SeaFoam
It's always best to plan a Seafoam adventure right before doing the plugs & changing the oil. You can do it by itself though.
The misfires happened during the Seafoam application. You should be able to clear the CELs without them coming back.
Old Jan 27, 2008 | 03:44 PM
bobbylight's Avatar
bobbylight
Default RE: SeaFoam
What are the CELs?
Old Jan 27, 2008 | 05:18 PM
tmodlin's Avatar
tmodlin
Default RE: SeaFoam
ORIGINAL: bobbylight
What are the CELs?
Check Engine Light, or MIL(Malfunction Indicator Lamp, lots of names.
Take it out and give it a little bit of the loud pedal, gotta get all that stuff cleared out of it. The code should clear itself after a few key cycles or you could disconnect the batt too.
Old Jan 27, 2008 | 07:16 PM
bobbylight's Avatar
bobbylight
Default RE: SeaFoam
Thanks, i disconnected the battery cable and it went out. Im very impressed with SeaFoam!
