2004 Dodge ram hemi shuts off
Old Feb 5, 2008 | 04:38 AM
scorpio210's Avatar
scorpio210
Default 2004 Dodge ram hemi shuts off
Hello thanks for looking and hopefully for teh help..... My 04 hemi sometimes when I come to a stop, red light etc. All the sudden it shuts off no hesitation nothing. Thankfully it doesnt do it while i am driving just as i come to a stop.. can anyone please help?
Old Feb 5, 2008 | 08:57 AM
helopilot's Avatar
helopilot
Default RE: 2004 Dodge ram hemi shuts off
Try this TSB, if it is what I think it is. Just complain of the symptoms listed.
http://dodgeram.info/tsb/2005/18-013-05.htm
Old Feb 6, 2008 | 07:39 PM
blindo73's Avatar
blindo73
replace you egr valve about 70$ from the dealer very easy fix
Old Feb 6, 2008 | 07:55 PM
tctwg's Avatar
tctwg
My 2004 hemi use to shut off too when i came to a stop. The dealer even did TSB, but that didn't help. The promblem was that when i had my transmissions filters change i was 5qts low of ATF, and after the dealer added that 5qts my truck never shut off again
Old Feb 16, 2008 | 08:18 AM
scorpio210's Avatar
scorpio210
thanks for the replys ive been out of town. will try suggestions thanks once again
Old Feb 18, 2008 | 06:04 PM
lonewolf3197's Avatar
lonewolf3197
I posted a reply for one of these last week, and I'll tell you the same thing. Mine was the brakes.When I would come to a stop the truck would die.I changed my pads and rotors and cleaned the speed sensor in the wheel hub and I haven't had a stalling problem since. I tried all the other answers on this site including the dealer reflash and nothing worked. I did a tune upcleaned the throttle body, you name it and nothing worked.After searching through the site for a few hours I saw a post suggesting the brakes. Gave it a try and it worked. Hope this helped.
The Wolf
Old Feb 18, 2008 | 07:28 PM
scorpio210's Avatar
scorpio210
hey thanks for the reply, i have had problems with the brakes they squeak like crazy and when I inspected them they still have more than half the pads left so i didnt change them. i am going to try that, hopefully it works. thanks once again
Old Feb 18, 2008 | 07:44 PM
TANKZ400's Avatar
TANKZ400
Brake's that crazy.
Old Feb 18, 2008 | 11:09 PM
lonewolf3197
I know it sounds wierd, but it worked for me. I had a very slight squeel when I would come to a stop, then the truck would shut off. If there was no squeel, it would be fine. I would suggest doing a proper break in on your pads when you change them out or the squeel could still be there. Mine did for the first couple of days, even with new rotors, so I warrantied the pads and broke them in as per my haynes manual and I haven't had a problem since. I hope you get it figured out. Later
The Wolf
