Front end shake over bumps
Power wagons have a TSB for tires as well....Here is the master link to TSB issues.......http://dodgeram.info/tsb/index.html
My trucks shaking doesn't have any thing to do with hitting bumps, it just shakes really bad when I get over pretty much 35mph. I cannot figure out what it is, and im getting so many different possible reasons, i would like to have a pinpoint answer. Does anybody have the answer?
i have the same exaCT problem on my 2005 ram 2wd, except my vibrates on bumps at a slow mph also, ive taken it to suspension shops, got it aligned bought new tires etc, an it still happens, also at about 65-70 mph the truck vibrates like the tire balance or alignment is off, but have dont both numerous times.. i would like some info also..
I have an 05 power wagon (2500 series 4x4) I just had the entire front steering link system replaced (all tie rods including a new beeferier steering dampener) My truck shakes uncontrolably when I hit a bump on the right side at speeds over 60 MPH. It is very scarry. The truck jumps and shakes the living hell outa me until I drop back down to about 40. I can then bring it back up to speed and continue on untill I hit another bump. I don't think your problem lies in the tie rods. I will keep you informed when I find out what the problem is.
My 04 2500 4x4 does this. It has 85k and at hwy speeds ( 70-80mph ) it bounces violently when the front end hits hard bumps. And like above I can back off the speed and it settles down. I have viewed several threads and reading opinions and ideas. I just replaced my shocks, steering dampener and had tires balanced and it still bounces/shakes like hell.
This post above descibes the problem as I have. Does anyone have a solution ?
