Front end shake over bumps
Hello, I am new to this forum and hope someone can help . I have a 2005 Ram 2500-hemi, 41k miles. Lately, at speed (60mph +) going over a bump where pavement changes on an interstate, the front tire or tires bounce almost out of control. Took it into a local shop and they want to do inner tie rods and steering damper, bal. and rotate tires and do alighment and they "hope" this will cure prob. I did a little internet snooping and it seems I am not alone. Anyone have any real world expierence with this and how did you deal with it. Thanks in advance.
i had that same symptom. i started checking for loose bolts and found the bottom bolts that hold the shocks on were just sitting in there not even threaded in. so i tightend them. problem solved.
Wow, Thats what I call Fast help!!! I was wondering about the shocks anyway. Can anyone recommend what shocks I should get for the Ram, both front and rear? And, should I change out the steering damper for an aftermarket one now and get it over with. Thanks in advance.
tsb 22-005-06 you replace the steering dampner and outter tie rods set tire pressures and preform alignment.
Trending Topics
I have an 05 power wagon (2500 series 4x4) I just had the entire front steering link system replaced (all tie rods including a new beeferier steering dampener) My truck shakes uncontrolably when I hit a bump on the right side at speeds over 60 MPH. It is very scarry. The truck jumps and shakes the living hell outa me until I drop back down to about 40. I can then bring it back up to speed and continue on untill I hit another bump. I don't think your problem lies in the tie rods. I will keep you informed when I find out what the problem is.
My trucks shaking doesn't have any thing to do with hitting bumps, it just shakes really bad when I get over pretty much 35mph. I cannot figure out what it is, and im getting so many different possible reasons, i would like to have a pinpoint answer. Does anybody have the answer?
