Ticking/Clicking Noise
Old Feb 24, 2008 | 02:06 PM
EspoMan's Avatar
EspoMan
Default Ticking/Clicking Noise
Hey guys, whenever I drive my ram on the road I hear this ticking or clicking sound coming from both front doors and its driving me crazy! If I apply pressure to the door it appears to go away. I am going crazy to the point were I want to take the door panels out of dynomat the f----ing thing. Does anyone else have this problem? Any manuals online on how to remove the door panels? thanks!
Old Feb 25, 2008 | 10:02 AM
EspoMan's Avatar
EspoMan
Default RE: Ticking/Clicking Noise
Anyone?
Old Feb 25, 2008 | 10:11 AM
VA4MEDS's Avatar
VA4MEDS
If you have to apply pressure, It sounds like the door lock jam might be a little loose.
Try jerking on the door from inside & outside to see if you hear anything.
Speed Safely,
AL
Old Feb 25, 2008 | 11:29 AM
EspoMan's Avatar
EspoMan
ORIGINAL: VA4MEDS
Speed Safely,
AL
Yeah but the wierd thing is that when I get home I open the door and try to play with the lock a little bit to see if it makes the noise but it doesn't. I even shake the door and I cant get it to make the noise. Its wierd and its driving me loco.
Old Feb 25, 2008 | 11:32 AM
Baddog543's Avatar
Baddog543
Does it sound like the door trying to lock type of sound when it is already locked??
Old Feb 25, 2008 | 11:34 AM
EspoMan's Avatar
EspoMan
ORIGINAL: Baddog543
Are you saying when im driving and the ticking noise is happening? No, just sounds like a tick or a click noise. Just like when you click your mouse on your computer, that type of sound but almost constant when im driving, even more if its a bumpy road.
Old Jul 31, 2008 | 09:42 AM
whipper's Avatar
whipper
Hello,
Did you everfigure out your noise?I have a similar issue. My noise is coming from my seat, I think, but I can not track it down.
Old Jul 31, 2008 | 02:47 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
my driver side window rattles when its nto completely closed or completely open. might that be your problem?
Old Jul 31, 2008 | 03:06 PM
whipper's Avatar
whipper
Thanks for the suggestion. It is definitely not the window. When it first started happening I thought was coming from the drivers seat. Then it went away. Then it came back and it is hard to isolate the sound. I still think it is coming from the drivers seat lumbar area, but I cant seem to locate it. It is not very loud, but is becoming more annoying by the day.
Old Aug 1, 2008 | 08:12 PM
hemi v8's Avatar
hemi v8
My truck, 2007 Quad cab had the same problem. The noise, at least in mine was with the oval ring around the door lock. What I did was cut a 1/2 inch square piece of 3M tape and put it in between the door and the oval. It took a couple of pieces in each, but it's as quiet as can be. I hope this helps.
