Subwoofer Question
Old Mar 5, 2008 | 12:19 PM
2005cobrakiller's Avatar
2005cobrakiller
Default Subwoofer Question
Picking up two low profile pioneer 12" subs 1400watt......I am wondering do u guys think a 2 channel 2000 watt amp will power these properly? or no?
Old Mar 5, 2008 | 01:33 PM
HighDuke1911's Avatar
HighDuke1911
Default RE: Subwoofer Question
does the RMS match up well on the amp and the subs? its all about RMS, not max
Old Mar 5, 2008 | 02:12 PM
2005cobrakiller
ill check into that
Old Mar 5, 2008 | 02:39 PM
casper3380's Avatar
casper3380
from prior knowledge, pioneer has high peak power ratings but their rms as well below half on average. those are probably around 50-350 watts rms. I wouldnt go more than 10% above that rating and only if its in a sealed enclosure.
Old Mar 5, 2008 | 03:10 PM
2005cobrakiller
well these speakers are saying 1400 watt max 350 nominal (rms) so im guessing a 800 or a 1000 watt 2 channel amp would work pretty good... i mean i am in a rcsb so its prolly gonna hit hard as hell right? let me know guys.....i havent done speakers since rockford fosgate was running **** and kenwood
Old Mar 5, 2008 | 03:51 PM
kx250frider617's Avatar
kx250frider617
get a mono amp and run the subs parrallel. mono amps have other adjustment only for subwoofers.
Old Mar 5, 2008 | 11:41 PM
Alaska700's Avatar
Alaska700
Let me know how those sound, and what Amp you end up going with.
I heard a lot of good things about those subs,,, I think I need one more totalk me into getting them.
What box did you have for them?? I see some boxes on ebay for about 75,,,any good?
thanks
Old Mar 5, 2008 | 11:50 PM
HighDuke1911
you need a 700w RMS mono block
Old Mar 5, 2008 | 11:55 PM
kx250frider617
remember you don't have to get a powerful amp. thats only if you know you want to turn it up and blow you truck apart. You can get a alpine amp thats called and mrp-450 i think and it will sound great. i got a amp thats 210 rms pushing one 12 and my overhead temp thing rattles like crazy, my rear veiw fell off when i was driving, it was the coolest thing i have ever seen. i would get a amp in your price range. it will be better to have everything match but a good quality amp will be fine.
Old Mar 6, 2008 | 12:01 AM
HighDuke1911
maybe because your sub only takes 200w RMS. his are 350 each. he needs a 700w RMS mono block amp.
