lamp out indicator
Old Mar 8, 2008 | 12:33 AM
dakota1955's Avatar
dakota1955
Default lamp out indicator
I have a 2005 Dodge Ram 1500 that shows an indicator light on the dash. It say "lamp out", but I've checked every light on this vehicle and they're all burning.
Can anyone help?
Old Mar 8, 2008 | 07:22 AM
Pyro's Avatar
Pyro
I Beat Tetris
Default RE: lamp out indicator
Check headlights, turnsignals front and back, brake lights, reverse lights, fog lights, and license plate illuminators.
Old Mar 8, 2008 | 07:58 AM
Jeffylee's Avatar
Jeffylee
Mine did that right after I got my truck. There were no lights out when the 'Lamp Out' light came on. The next day my brake light went out. I assume it can sense the voltage change or something as the bulb is about to go out.
Old Mar 8, 2008 | 08:11 AM
hocheck's Avatar
hocheck
My 02 was doing the same thing. It would do it all the time on a bumpy road. It turned out to be a bad connection on the driver side brake light.
Old Mar 8, 2008 | 10:03 AM
Baddog543's Avatar
Baddog543
Do yourself a favor and pick up some brake/turn signal bulbs, everytime that mine has done that one finally ended up going out.
Old Mar 8, 2008 | 12:10 PM
jstmahoney's Avatar
jstmahoney
the truck will actually sense the light is going out before it does.
Old Aug 30, 2010 | 09:24 AM
tjwaite1's Avatar
tjwaite1
Default Lamp out indicator how do i fix?
I have a 2003 dodge ramn 1500 5.7 hemi and the lamp out indicator keeps coming on all my lights work and are on but it will ding come on go out ding come on go out some times it will ding for like five minutes how can i fix this problem?
Old Aug 30, 2010 | 01:23 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Go pull the tail lights out and check the plastic circuit boards. Chances are they are shot as those years had issues with melting and shorting out
Old Aug 30, 2010 | 10:58 PM
Atwiss's Avatar
Atwiss
same thing happened to me and i thought everything was good until i had someone press the brake and it didnt get brighter so have someone do that
Old Feb 8, 2011 | 11:27 PM
tkoco2007's Avatar
tkoco2007
Default Lights Out
I know it probably late but I had the same problem and it was really getting to me. So I was always thinking about it. Then it finally hit me one night when someone flashed their brights at me. So i checked my brights and sure enough one was out.
Hope this helps.
