LIFTER TICKS AT START UP.......
Old Mar 10, 2008 | 11:03 AM
0522S's Avatar
0522S
Default LIFTER TICKS AT START UP.......
MY GOAT HAS 50K MILES, SHOULD IT BE DOING THIS? I DID A FRESH OIL CHANGE 5W 30 CASTROL BUT SHOULD I RUN SYNTHETIC????????? THE TICKING GOES AWAY AFTER ITS WARMED UP
Old Mar 10, 2008 | 11:40 AM
ride_002000's Avatar
ride_002000
Default RE: LIFTER TICKS AT START UP.......
Mine is there when its cold. It stops for about a week after an oil change and then starts back up. And it doesnt go away even when the truck is warmed up, just in cold weather it ticks. Its not too bad but I can notice it. Mine has 95,000 miles tho but noticed it at about 78,000. I heard some Lucas oil works good to get rid of it for awhile.
Old Mar 10, 2008 | 12:03 PM
Baddog543's Avatar
Baddog543
I just started a slight ticking in mine, I have 95000 miles on it.
Old Mar 10, 2008 | 12:09 PM
PyRoHAvoC's Avatar
PyRoHAvoC
68k here and i have a tick as well but once the truck is warmed up it goes away
Old Mar 10, 2008 | 01:48 PM
0522S's Avatar
0522S
WELL HELL!!!!!!! GUESS ILL RUN HER TIL SHE BLOWS
Old Mar 10, 2008 | 02:57 PM
cpukramer's Avatar
cpukramer
I have the same problem ... just started about two weeks ago (was very cold around here ... like 10 degrees). I am just about due for an oil change so I guess I will do that and see if that helps at all. I always run Mobil 1 Synthetic.
Old Mar 10, 2008 | 03:09 PM
ride_002000
I also had a lifter tick in my 1990 ranger and ran her until 160,000 with no problems. I was told it wont hurt it.
ramman59's Avatar
ramman59
All you need to check the gap onyour lifters and rockers. it ticks in the cold and start up because the gap is too big and you have no or low oilpressure. I had a 90' dakotathat did the some thank.
Old Mar 10, 2008 | 03:18 PM
ramman59's Avatar
ramman59
or you you need a new lifter
Old Mar 10, 2008 | 03:21 PM
0522S's Avatar
0522S
TO DO THAT ISNT THAT A PRETTY BIG OR DEAL TO CHECK GAP..... ITS THE WHOLE HAVING A NEWER TRUCK THAT I PAY 400 A MONTH FOR AND THE THING SOUNDS LIKE A ****BOX. I TRIED TO FIGURE OUT IF I HAD A WARRANTY BUT IM STILL WAITING ON A PHONE CALL
