Fog Light Trouble
Old Mar 19, 2008 | 04:59 PM
william.rawe's Avatar
william.rawe
Default Fog Light Trouble
I have a 2008 Ram 1500 SXT. I installed the fog lights and the dealer initiated the lights for me. Now the ABS and brake warning lights are on and the cruise control does not work but the fog lights do. Any ideas?
Old Mar 19, 2008 | 07:35 PM
johnsaballer's Avatar
johnsaballer
Default RE: Fog Light Trouble
i'm assuming you've unplugged them to see if the issue goes away? also did you disconnect the neg terminal from the battery before installation?
Old Mar 19, 2008 | 07:41 PM
CRMRAM's Avatar
CRMRAM
Might wanna take it into the dealer sicne probably the guy goofed something up with your ECU.Everything on these trucks is pretty much controlled by the Computer.You canalso try resetting your truck by removnig the Negative from your battery.
Old Mar 19, 2008 | 07:46 PM
CarGuyOhio's Avatar
CarGuyOhio
Yea, I would not even wager a guess. New truck, dealer.
Old Mar 19, 2008 | 08:22 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: william.rawe
I did the same thing as you the other weekend and haven't had a prob so far.
Like the other guys said, the dealer that used the starscan probably did it wrong. Did you stand there and watch him do it? Was he fumbling around in the menus trying to find the right one...or more importantly did he turn the igniton off for 10 seconds and then back on for 10after programming? If he just programmed it and then unplugged the starscan from the DTC port you'll have problems..
Old Mar 19, 2008 | 09:15 PM
Parts/Service's Avatar
Parts/Service
I would go back, If he enabled the fog light output with the star scan correctly, it should have not caused problems.
Old Mar 20, 2008 | 03:08 AM
SmokeySportRam's Avatar
SmokeySportRam
go back and bitch like crazy....
you spent how much and now they mess up the truck??
Old Mar 20, 2008 | 11:17 AM
JimmyDiablo's Avatar
JimmyDiablo
Now that is effin Awsome.
Old Mar 20, 2008 | 11:10 PM
SmokeySportRam
thank you!!
everybody that sees it likes it (its actually the wife coming home from work that day, i was running the camera, check out the link in my sig and you can see more pics (not quite as spectacular)
