AIR RAID OR K&N
Old Mar 30, 2008 | 11:38 AM
damram1980's Avatar
damram1980
Default AIR RAID OR K&N
I am gonna buy an air filter setup and was wondering what u guys r usin and what kind of results ur getting,
iknow theres a lot of posts on this but figured it was a good idea to get fresh answers, cause theres always newer tech.
Also whats the word on throttle body spacer? they say it gives better air flow is this true?
CHECK OUT THESE ENGINE COMPARTMENT ACC. http://www.stylintrucks.com/parts.as...d_prod_ids=317
THIS IS WHAT IM THINKIN OF BUYIN:http://www.stylintrucks.com/sn.aspx?...28=Performance
Old Mar 30, 2008 | 11:44 AM
daytona1680's Avatar
daytona1680
Default RE: AIR RAID OR K&N
dont waste the money on the throttle body spacer, unless you plan on adding nitrous to your truck. throttle body spacers make good paperweights. for a filter I would use a dryflow filter I.E AEM, trueflow, etc..I currently am running a dual cone intake with 2 fram airhogs and they seem to bring in alot of air, but after hearing of some people having problems with oiled filters I will be using dryflow filters when my engine goes back together
Old Mar 30, 2008 | 11:48 AM
damram1980's Avatar
damram1980
so ure runnin double intake? or 2 cones off 1 line?
i was gonna get the whole assembly http://www.stylintrucks.com/
Old Mar 30, 2008 | 11:59 AM
daytona1680
I "T" out of the throttle, onefilter runs upto my hood scoop, the other goes over to the factory location....
I used to order through stylin, but I quickly found most of there stuff is over priced. I now order pretty much all my stuff from http://moesperformance.com
Old Mar 30, 2008 | 12:01 PM
damram1980's Avatar
damram1980
hows it run with all that air? did u have to get a hotter spark plug?
thanks 4 the moes link
Old Mar 30, 2008 | 12:06 PM
daytona1680
It runs pretty good, but I have the free flowing exhaust to go with it. With that said I had it on my 4.7 originally and it made my throttle response better, I only had a dual catback on that truck at the time I installed the intake
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
ORIGINAL: damram1980
Without forced induction a engine will only pull in the air it needs...no more or less (unless it's restricted). So if you throw in a cam, heads and headers you'll get better use out of that CAI...which is why it's a supporting mod.
Old Mar 30, 2008 | 12:10 PM
daytona1680
exactly...in about 4 days I have a cam and new valvetrain going in my truck
Old Mar 30, 2008 | 12:25 PM
SeVeReDiStOrTiOn
^^^Sweeeet!! What's the specs on the cam you're getting?
Old Mar 30, 2008 | 12:28 PM
damram1980's Avatar
damram1980
yeah thats still a dream 4 me lol what about those chips/programmars i keep reading about? is it worth it if all is stock? after reading about that guy who erased his comp im a little sketchy lol
