Changing The Fluids
Old Apr 3, 2008 | 12:41 AM
mmstar23's Avatar
mmstar23
Default Changing The Fluids
Ok, so this weekend im going to be cahnging out my transmission fluid and filters. Also my engine oil and oil filter. and while im at it ill probably do my differential.
so to start....i have an 02' with 90,000 miles on it. what weight oil would you use?
2nd.....what fluid do i need for my transmission....i couldnt find any Royal Purple for automatic trans...just manual, so id probally get penzoil unless someone tells me different.
3rd my differential....what weight was it exactly? 75W-90 or was it 75W-140............i have a 2wd so only the rear.
engine oil and differential will be royal purple and the oil filter will be a mobil 1. not sure what to do with the tranny like what filters and what fluid to use.
thanks
Old Apr 3, 2008 | 12:57 AM
Tractor's Avatar
Tractor
Default RE: Changing The Fluids
CHECK YOUR MANUAL !!! Can't stress that enough. I would use RP5w30 in engine-75/90 in differential-and ATF+4 in transmission. Even if it calls for ATF+3, ATF+4 is a better lubricant and can be used but NOT the other way around. You may have 2 filters in trans. A long flat one and a spin on one. Our 04 did. Hope this helps.
Old Apr 3, 2008 | 01:09 AM
daytona1680's Avatar
daytona1680
RP makes auto tranny fluid I'll see if I can find a link to it real quick....
Old Apr 3, 2008 | 01:12 AM
daytona1680
ok, here ya go
http://www.hensonmotorsports.com/mer...tem.php?id=771
Old Apr 3, 2008 | 01:28 AM
mmstar23's Avatar
mmstar23
thanks daytona. i guess ill just have to buy the transmission fluid from royal purple elsewhere because my shop doesnt sell it for some reason.
and tractor......if i had a fu*kin manual i would use it but i dont have one!
you still think use 5w-30 with that many miles on it? i thought it was 75/140 for the rear differential...
Old Apr 3, 2008 | 01:40 AM
daytona1680
ORIGINAL: mmstar23
for engine I use 5w-10 rear is 75w 90
not sure how much your paying for RP. this place may be cheaper
http://www.hensonmotorsports.com/mer...ex.php?cat=364
Old Apr 3, 2008 | 01:45 AM
mmstar23's Avatar
mmstar23
haha.....i dont have to worry about the price. i just need the right stuff. all my fluid necesities are FREE.
ive hear that chrysler 9.25 axle recomends 75/140 for the rear....you guys tell me 75/90
and i thought id need something thicker than 5w-30 for motor oil.
Old Apr 3, 2008 | 01:53 AM
daytona1680
ORIGINAL: mmstar23
where i got the 75/90 was from that RP link i gave...75/140 was also a option..that link is an actual dodge dealer
and as for engine the factory says 5w-20..remember lighter in hot weather, heavier in cold weather...i personally run mobil-15w-10 all year though
Old Apr 3, 2008 | 07:05 AM
MikeHTally's Avatar
MikeHTally
Rear diff fluid is 75w-140 in the '03s The 02 is probably the same. ATF+4 for the tranny. The two-filter transmission is only for '03 and up, I think. That's the 45FRE or the 545FRE transmission. 5w-20 oil is for the MDS engines. My '03 calls for either 5w- or 10w-30, depending on how hot the weather may be. 5w for cooler climes, 10w for temps in the 100s.
Old Apr 3, 2008 | 10:10 AM
mmstar23's Avatar
mmstar23
i figured RP 75/140 for the diff.
RP 10w-30 for motor oil
and penzoil ATF+4 for the tranny
