speakers
Old Apr 12, 2008 | 01:24 PM
  #21
mmstar23's Avatar
mmstar23
Default RE: speakers
ya...just turned it loud as hell with bass to -6 and it sounded fine....looks like i need a sub to compensate....now if i hook up an amp to my front doors....do i need another amp for my sub or can i leave the sub?
Old Apr 12, 2008 | 04:36 PM
  #22
greg14_00's Avatar
greg14_00
If you hook an amp to your speakers you will get a way better sound for sure, but if you want bass you would be better off getting a sub and an amp.
Old Apr 14, 2008 | 01:34 AM
  #23
mmstar23's Avatar
mmstar23
alright thanks. ill try and hook up the amp to my doors and then look into a sub and hook that to an amp too. do i need any speacial battery or anything to power all this, especially when it hits or not really?
Old Apr 14, 2008 | 10:05 AM
  #24
satansfx's Avatar
satansfx
ORIGINAL: mmstar23
Im sure some "pro" is going to come in here and tell you "you should get XXXX battery with X farad cap running with 0/0 power wire that way made from unicorn horns"
Basicly this..... Do you need a new battery? NO Do you need a cap? NO Do you need 0/0 gauge wiring? Depends on how much power your going to run.
Old Apr 14, 2008 | 10:23 AM
  #25
mmstar23's Avatar
mmstar23
my battery is fine. wish i went with the optima, but i got the bosch. all im looking to do is amp my doors and throw like one 10 in the back or maybe a 12 and run that to an amp. thats it.
Old Apr 14, 2008 | 10:33 AM
  #26
satansfx's Avatar
satansfx
just run a 4ga. wire from the battery to the rear on the DRIVERS side. You can come in from the firewall by the hood cord.
Just make sure to use a grommet arround the hole so the wire doesnt rub against the roughed up metal. Or you can use rubber hose, just get slightly larger than the power wire and smaller than the hole you drill for the power wire... This way the hose protects the power wire from the firewall. Also remember to use some gasket seal arround the hole both in/out of the cab.
GL running the speaker wires from the rear back up front and into the doors, fun stuff there [:-]
