Best place to run a wire from engine bay to cab?
Old Apr 15, 2008 | 12:43 AM
ivaskaj's Avatar
ivaskaj
Default Best place to run a wire from engine bay to cab?
I am going to buy some driving lights tomorrow, but this time I want to do it right. No more redneck drilling a hole thru the firewall. Where has everyone here run their auxiliary wiring? Is there any factory opening that I can take advantage of, preferably in a place where a non-flexible fat *** like myself can get to easily? Thanks.
Old Apr 15, 2008 | 12:54 AM
RamItOne's Avatar
RamItOne
Default RE: Best place to run a wire from engine bay to cab?
facing the truck look on the driver side, youll see a bunch of wires going into a hole.
Old Apr 15, 2008 | 12:56 AM
ivaskaj's Avatar
ivaskaj
Where does that hole come out? (It's freezing outside and I don't feel like putting on clothes right now...and I'm lazy)
Old Apr 15, 2008 | 01:05 AM
daytona1680's Avatar
daytona1680
That hole will come out to left side of the steering column inside the cab, will have to unscrew that knee panel on the driver side to get to it....And whats redneck about drilling a hole in the firewall? Thats the right way to do wiring
Old Apr 15, 2008 | 01:23 AM
RamItOne's Avatar
RamItOne
you're driving a dodge, dodge is southern for redneck.
Old Apr 15, 2008 | 03:08 AM
ivaskaj's Avatar
ivaskaj
Well, when you use a 1/2" drill bit to run a 20 gauge wire just because it's convenient, then "seal" it up with duct tape, that's pretty redneck. This is my first vehicle that's worth anything, so I'd rather not cut or drill it unless absolutely necessary.
Old Apr 15, 2008 | 05:09 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
well...then drilling a hole isn't the redneck part...it's the sealing it with duct tape part that is. rubber grommets ftw,
Old Apr 15, 2008 | 06:47 AM
MikeHTally's Avatar
MikeHTally
Look on the firewall, just inboard of the brake booster. There should be a black plastic plate, shaped like a stretched diamond. It covers where the clutch pedal linkage would go (this assumes you have an automatic ). Very easy to drill through and run wiring. All the cables I've added go through it.
Old Apr 15, 2008 | 10:00 AM
Scott06HEMI's Avatar
Scott06HEMI
I used the plate that MikeH is talking about to run the video and power wire for my reverse camera and I'm going to use the same hole to run the wire to a light to show me when I'm in MDS mode. If you want to do it right, then drill there and either use a grommet or some type of black silicone but to be honest, no one is going to see it there so just take out the plastic cover, drill a hole 'just' big enough for the wire and bolt the plastic plate back on.
Old Apr 15, 2008 | 11:04 AM
satansfx's Avatar
satansfx
ORIGINAL: Scott06HEMI
Ilight to show me when I'm in MDS mode.
What is this MDS mode??? I searched but it's only talk about being in it and hating it lol
