please help me
Old Apr 26, 2008 | 09:29 PM
raptor700's Avatar
raptor700
Default please help me
I have a problem. I have a 2003 dodge ram regular cab with a hemi. It vibrates when i am going around a corner below4 mph. It is either when i am barely moving or when i am stopped and start to move. But the weird thing is thatit only happens when im turning. I put the truck in neutral and shook the drive line and the output shaft in the tranny moves about a millimeter. I may think this might be the problem but i am stuckon why it only happens around a corner. Does anybody know what may be the problem? I also checked the tranny fluid for any burning smell, checked motor and tranny mounts. Thanks
Old Apr 26, 2008 | 10:00 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: please help me
You sportin' IFS?
Old Apr 26, 2008 | 10:31 PM
raptor700's Avatar
raptor700
What is IFS?b
Old Apr 26, 2008 | 10:42 PM
Hemipwr07's Avatar
Hemipwr07
indepedent front suspension homie..ha i gots you
Old Apr 26, 2008 | 10:43 PM
dirtydodge02
IFS = Independant Front Suspension. Is your truck a 1500?
Old Apr 26, 2008 | 10:45 PM
dirtydodge02
And this may sound stupid, but I've seen in done... Your lugnuts tight?
Old Apr 27, 2008 | 09:02 AM
Gone Fishin's Avatar
Gone Fishin
Uh,
It may be time to add some more treatment to the rear diff. When that friction modifier gets old, it starts to go away and you get that weird popping vibration from the rearend. It caused by the clutches grabbing and releasing. Maybe its just time to change the gear oil. Oh, I should say that this only applies to LC-LSD's (1500's).
If you're running a one-tire-fire setup, its something else. You may also want to check to see if a caliper is hanging up a little too.
Just my .02
Old Apr 27, 2008 | 09:25 AM
greg14_00's Avatar
greg14_00
it might be stuck in 4x4, a friends gmc did that and that was the problem.
Old Apr 27, 2008 | 08:09 PM
raptor700's Avatar
raptor700
Okay i do have a 1500 2wd with IFS. I just bought a tranny service kit , tranny fluid and differential fluid. I will change them out since i have never done that since i bought the truck a couple months ago. I will do a bunch of work this week in my autoshop. Change engine oil, shift kit, tranny service, rear lowering shackle kit, and differential. I have a posi and i know a posi will virabrate around corners some but it shouldnt be this bad. I think the problem is in the differential.
Old Apr 27, 2008 | 08:48 PM
MikeHTally's Avatar
MikeHTally
I was thinking the diff as well. The friction modifier will only be needed if you have LSD.
