Front leveling & tire rub on an 08 Ram 1500 2wd...
Old 04-30-2008, 11:14 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
Default RE: Front leveling & tire rub on an 08 Ram 1500 2wd...
To my understanding, a Wheel Adapter/Spacer like this one
http://www.ezaccessory.com/Wheel_Ada.../5550-5550.htm
Will make the whole rim and tire stick out one-and a quarter inch out from what it is now...With no spacer.
All I want to do is get a good - heavy duty spacer (for towing also) and get rid of the tire rub against the upper front A-arm...
  #22
Old 04-30-2008, 11:18 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
like i said, depends how much they rub. i have 12" wide tires and they are pretty close to rubbing at full turn, so im pretty sure a 12.5" wide tire will rub, just barely though..so a 1/4" spacer will be perfect. it just depends on how bad it rubs.
yes thats what the spacer looks like with the new lugs. a spacer i was thinking of...the 1/4" is just a metal plat thats a 1/4" think with holes for your exsisting lugs to go through. and your done. just make sure all the lugs are tight and check the periodically to make sure everything is safe
  #23
Old 04-30-2008, 11:35 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
Thanks for the info MMStar23...
I think I might go with an inch if I can find it or maybe a 1.25" spacer just to be sure I get no more tire rub...
Gonna call 4Wheel Parts tomorrow to see what they recommend...Who know's I might only have to go 1/4" to clear...
  #24
Old 04-30-2008, 11:41 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
no problem. maybe get out of your truck, have someone turn the wheel all the way to one side and another and see just how much it rubs. IMO id try to keep the spacer as small as possible, but thats just me.
  #25
Old 05-01-2008, 08:20 AM
Scott06HEMI's Avatar
Scott06HEMI
Scott06HEMI is offline
I have 35x12.5x20s and used a 1/4" spacer and it seems to clear the upper arm fine now. When moving slow and in a hard turn (coming out of my drive way in reverse) I used to feel a vibration that felt exactly like the nubs on the outside edge of the tire rubbing on that arm. Now with the 1/4" spacer I no longer feel it. My guesstimation is that the extra 1/4 inch was enough to clear those nubs from the arm. Now I'm not saying that spacers are perfect, I know they have some bad qualities too, but it fixed my problem and I don't think they will stress my studs to the point of breaking at only a 1/4". 1/2" and I'd be worried.
  #26
Old 05-01-2008, 03:06 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
thats what im saying.i dont think such a minor amount would cause a problem to your studs.
  #27
Old 05-01-2008, 08:34 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
No more tire rub!!!
1/4" spacers did the job! Had them installed on all four wheels and you can't even tell!!!
Thanks for all the help and replies...
  #28
Old 05-01-2008, 09:57 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
glad that worked man. and im glad to hear you can barely tell.
  #29
Old 05-03-2008, 10:09 AM
5corpi9's Avatar
5corpi9
5corpi9 is offline
How do I post pics here? What's the max size the pic can be?
Quick Reply: Front leveling & tire rub on an 08 Ram 1500 2wd...
