03 hemi
Old May 1, 2008 | 10:26 PM
ray97's Avatar
ray97
Default RE: 03 hemi
ORIGINAL: HemiLonestar
Premium is not recommended. Right out of the owners' manual, 87 is ok, 89 is recommended.
I agree right out of the book, 89 is the recommendation.
Old May 2, 2008 | 06:56 PM
HemiLonestar's Avatar
HemiLonestar
Default RE: 03 hemi
And I quote..."The routine use of premium gasoline is not recommended. The use of premium gasoline will provide no benefit over high
quality regular and mid-grade gasolines, and in some circumstances may result in poorer performance."
Old May 2, 2008 | 11:23 PM
John  M's Avatar
John M
Default RE: 03 hemi
With the Superchips programmer and the "power wire" resistor mod, I don't mind using 93 just in case. Why complain about a $5 difference in fillup cost when you're over $70 anyway?
Old May 3, 2008 | 12:05 AM
Stunnerguy's Avatar
Stunnerguy
Default RE: 03 hemi
so i guess i'll just start putting in 89, sincetheCAI is the only MOD
Old May 3, 2008 | 12:17 AM
Stunnerguy's Avatar
Stunnerguy
Default RE: 03 hemi
Damm this is the best place to get ur answer's... Thanks guys
Old May 3, 2008 | 10:12 AM
toxdoc's Avatar
toxdoc
Default RE: 03 hemi
ORIGINAL: John M
Using 93 octane since new in my 05' with SuperChips set on theperformance tune and other additional performance mods too; so far so good - but cheaper fuel prices would certainly be welcome as well.
Old May 3, 2008 | 06:55 PM
HemiLonestar
Default RE: 03 hemi
With the hot rod setting from a programmer, thats a little different. Your ignition timing won't retard with lower octane fuel like the factory setup would. Need to use premium then.
