cranking tbars = not level?
Old May 4, 2008 | 08:02 PM
05Redram's Avatar
05Redram
Default cranking tbars = not level?
Today I was cranking my torsion bars and I measured the distance between the fender and the top of the rim. In the back it was 14in and the front 12in. I have almost completely tightened the bolts and the front only went up to 13in. How many people have actually gotten their trucks level from the tbars?
Old May 4, 2008 | 09:13 PM
greg14_00's Avatar
greg14_00
Default RE: cranking tbars = not level?
I cranked mine all the way once and it was 1" higher in the front then it was in the back, but then lowered it to be level.
Old May 4, 2008 | 11:56 PM
BEAR's Avatar
BEAR
I cranked mine about 5 1/2 to 6 turns and raised it 2 1/2 inches. Mine is level now. 5ont understand why yours isn't, maybe you need a leveling kit.
Old May 5, 2008 | 12:02 AM
mmstar23's Avatar
mmstar23
did you jack up the truck when you were tightening the bolts?
Old May 5, 2008 | 07:43 PM
05Redram's Avatar
05Redram
I did jack the truck up when I did it but I only turned the drivers side 3.5 and the passenger 4 turns.
It doesn't look like it will go much farther though. Maybe I'll turn them some more...
Old May 6, 2008 | 05:03 PM
irelandshemi's Avatar
irelandshemi
two questions, can someone post a picture of what bolt im supposed to be turning, and also will that have to be undone before i do a body lift?
Old May 6, 2008 | 05:31 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: irelandshemi
Get under the truck, there are two long bars running from the suspension towards the doors. Follow them back and you'll see them end at the Keys. At the bottom of the keys there is a bolt, the head points at the ground. These are the bolts you need to crank.
No need to crank down for a body lift, unlike a suspension lift, a body lift does NOT level the truck. So a good combo to have, if you can't afford or refuse to spend the $$ on a suspension lift, is a body lift with either a level kit or the front bolts cranked...
Oh, and 05Ram, something is not kosher there. I've cranked the bolts on 2 different friends trucks, and there was enough cranking room to actually get the front higher than the back. Keep in mindthough, the higher the crank, the stiffer the ride...
Old May 6, 2008 | 08:22 PM
irelandshemi
so just jack it up and turn the bolt on each sides no like pulling things out or anythign?
Old May 6, 2008 | 08:23 PM
irelandshemi
my bad on another post but i forgot to ask with that bolt just use like a socket head or any special tool
Old May 6, 2008 | 10:48 PM
HammerZ71's Avatar
HammerZ71
Measure the distance between the top of the tire and the top of the tire well. Jack the truck up and turn the bolts on each side a few cranks, regular socket is fine. Let the truck down and re-measure. Raise it back up and adjust it where you want it.
It may take a couple of ups & downs to get both sides perfect and don't be surprised if you have to crank one side more than the other for the same lift height.
That's all there is to it except you should get an alignment soon after doing it...
