Old 08-10-2015, 05:36 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Are Cold air intakes worth the money.
Old 05-13-2008, 08:10 AM
deerjunkie's Avatar
deerjunkie
deerjunkie is offline
Default RE: Are Cold air intakes worth the money.
In my opinion the RamHammer is the ultimate CAI (even though I don't have one) for this reason. Look at its design.....large opening then as it enters the TB it gets smaller. As air travels from large to small openings it increases in speed essentially putting more air into the cylinders. If I could just break this bowhunting addiction mybe I could get a RamHammer CAI lol.
  #22
Old 05-13-2008, 08:22 AM
bwhite757's Avatar
bwhite757
bwhite757 is offline
ORIGINAL: L and R Two
That ebay one pictured above has the cone covered and really doesn't do much.
The cone is covered with a heat sheild, same as the true flow CAI, it originally came with a K&N cone that was not covered, still no difference, and more noticiable EGR valve noise... I actually like the covered cone better...
Before:
After:
  #23
Old 05-13-2008, 09:42 AM
Max Power's Avatar
Max Power
Max Power is offline
No dyno info here but the "butt" dyno, and based on actual fuel mileage changes, my exhaust and Superchips showed measurable improvement, while my CAI showed almost no change, other than an annoying whistling sound. If I had to do it over again, I wouldn't.
  #24
Old 05-13-2008, 11:49 PM
HemiMega's Avatar
HemiMega
HemiMega is offline
I do have HD 50 Flowmaster on it. That opens the exhaust some. I think I'll just get a drop in for it...
  #25
Old 05-14-2008, 11:37 AM
dline's Avatar
dline
dline is offline
oh if your doing it on a 4.7L your wasting your time.....get a HEMI!
  #26
Old 05-14-2008, 11:46 AM
SLCHemi's Avatar
SLCHemi
SLCHemi is offline
HammerZ71 said it all, a CAI, like many other mods needs to be done in concert with other things to actualy realize gains worth your time. And as other has pointed out, allot of those gains are often only seen in higher RPM ranges anyway...so technicaly unless your runnin' er hard all the time you never feel it......all that said, I've bought 'em for the last two truck I own and I drive like a grandpa I like thinkin' it's there if I want it, and appreciate other attributes (i.e. re-useable filter, etc..), and I cannot deny the cool factor - it just plain looks better than the fugly air box
  #27
Old 05-14-2008, 03:18 PM
jonnymagnum's Avatar
jonnymagnum
jonnymagnum is offline
im gettin a ramhammer this summer
  #28
Old 05-14-2008, 08:09 PM
RaiderJay6's Avatar
RaiderJay6
RaiderJay6 is offline
The Ram Hammer is the way to go on a CAI. I improved .2 on the track and the only difference was the RH. I thought my old ram air setup was the way to go but after reading more and more people loving the RH I got one and its awesome!
  #29
Old 05-14-2008, 08:42 PM
WhiteRam's Avatar
WhiteRam
WhiteRam is offline
Here's a question..... I was thinking about toying with a "ram-airish" tube from the fog light hole, up towards the stock air filter box? Any thoughts?
  #30
Old 05-14-2008, 09:01 PM
Citizen Shane's Avatar
Citizen Shane
Citizen Shane is offline
ORIGINAL: WhiteRam
It's only going to make power once you are going about 50mph. It takes about that much force to push the air up thru the tube and down the throttle body. When you are going any slower than that it will behave much like a stock intake.
Quick Reply: Are Cold air intakes worth the money.
