how often for oil change?
Old May 15, 2008 | 01:36 PM
cddailey's Avatar
cddailey
Default how often for oil change?
I think i seen in the manual that you do it every 3,000 or 6,000. I drive highway to work about 5 miles or so and i dont drive all that much. maybe driving around town and work is under 1,000 miles a month. When does everybody get theirs done?
Old May 15, 2008 | 01:47 PM
RedneckDodge86's Avatar
RedneckDodge86
Default RE: how often for oil change?
Depends on what kind of oil you have. If you are running regular motor oil it would be in your best interest to change the oil/filter every 3000 if you care about your truck. If you are running sythetic u can change it every 6,000 to 12,000 depending on the kind. Royal Purple is rated at 6,000 i think and AMSoil is "said" to be rated at 12,000. But i reccommend putting RP in it, and so do alot of other people on this site.
Old May 15, 2008 | 01:53 PM
Wapakfred's Avatar
Wapakfred
I run Mobil 1 in mine and change it every 5000. It's a easier to remember that way.
Old May 15, 2008 | 01:58 PM
cddailey's Avatar
cddailey
I normally get just regular Castrol GTX oil.
Old May 15, 2008 | 03:07 PM
RamWood's Avatar
RamWood
Remmber that it's not just the miles you put on the truck but the time the oil sits in the engine too.
I think normal oil will break down if you just let it sit for about 3 1/2 months witout even starting the truck
Old May 15, 2008 | 03:39 PM
cddailey's Avatar
cddailey
well i drive my truck everyday i just dont put alot of miles on it each day.
Old May 15, 2008 | 03:56 PM
MikeHTally's Avatar
MikeHTally
I changethe oil in my Ramevery 3K. My new Speed3 specifies 7,500 (on a turbo!!). That will be ignored. Will probably change it at 1k, then at 5K and 10K. Then I'll switch to synthetic in the Mazda and still change it every 5K.
Old May 15, 2008 | 04:11 PM
jstmahoney's Avatar
jstmahoney
I have always changed my oil at 3K.
Old May 15, 2008 | 05:11 PM
redtruck2500's Avatar
redtruck2500
My truck has told me every 2700 miles for the 1st 2 oil changes.
Old May 15, 2008 | 05:36 PM
stratusguy02's Avatar
stratusguy02
I would just use regular oil and change every 3k. If the oil breaks down, your motor is done. Especially with today's engines.
