3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
so iv been wanting to crank them for a while to make it level but im still unsure what they look like, are they the bolts that my running bars are attached at, if anyone has a picture that would be great
Follow the torsion bar back toward the cab, it ends at the torsion key, the key bolt is the one with the head sticking straight down, just like bpv's pic...
they are BFG all terrain T/A KO35x12.5 they rubbed a lil bit before. and now they dont rub at all
how doeas sometyhing rub at one time, at another, with no mods....they dont rub....what did the side walls wear down or something?
He means that the tires rubbed before he turned the torsion bars. I'm not sure how tires rubbing on the sidewall hold up in the long run. Can't be too good for them.
ahh gotcha....thanks for the clarification. thought he meant it rubbed on the sides, because mine are probally gonna rub on the sides since i barely have any clearance, and im going with a wider tire, but a spacer will fix that
