Leveling kit question
Old Jun 22, 2008 | 01:13 PM
Junior000's Avatar
Junior000
Default RE: Leveling kit question
Mmstar whered you find the longer shocks at? As I read everywhere you dont need longer shocks. I put the leveling kit in my truck yesterday. The last shock I put the top nut on with the truck on the ground, Tighting the nut pulled the truck down. So the shock couldnt extend anymore and holy **** hitting anything in the road the front end bounces all over, the shock cant extend anymore. So if I can get this alignment issue worked out I need longer shocks..
The 2" longer uncompressed, 1" longer compressed shold work fine for me. Put a 2in spacer... whats the shock off of??
[hr]
Old Jun 22, 2008 | 01:22 PM
butch1581's Avatar
butch1581
if you have an 06 or newer you dont get longer shocks because you dont have them you have struts! just put the spacer in on top of the strut and its good. (Although putting the spacer in is harder than they make it sound!)
Old Jun 22, 2008 | 01:27 PM
Junior000's Avatar
Junior000
Lucky for 06 and up..Im an 05..s.o.l.
Old Jun 22, 2008 | 01:31 PM
mmstar23's Avatar
mmstar23
ORIGINAL: Junior000
[hr]
well mines an 02, so i have shocks. i dont know what yours is. but if you have shocks...a regualar shock off a 2500 2wd is what you need
Old Jun 22, 2008 | 01:34 PM
Junior000's Avatar
Junior000
Alright, who do you work for in broward? If i can get my alignment issue worked out Ill come by and see ya.
Old Jun 22, 2008 | 01:42 PM
mmstar23's Avatar
mmstar23
my guys did my truck no problem. took him 20 minutes. and my camber was bad on my old tires with my stock shocks and 2.5" leveling kit.
i work at pepboys in plantation on sunrise blvd and flamingo. if you stop by, come later in the day like 6 or 7. we have a guy named hector in the shop who specialiizes in alignment. but he only works from like 5 to 9
Old Jun 22, 2008 | 01:47 PM
Junior000's Avatar
Junior000
I took it over to sears at broward mall, Buddy from dodge said they do a good alignment ( hard to get one done right) . My truck before I put the spacers in I guess was already maxed out on camber.. and like I said tighening the shock down pulled down on the truck. So once I put the longer shocks, camber will need to be adjusted again. Dont know if its a good idea to grind that slot longer, seems to be enough material there..
Old Jun 22, 2008 | 01:59 PM
mmstar23's Avatar
mmstar23
i dont know about the grinding, but id go get your shocks first, otherwise you'll just be wasting money. speeda and truck world has rancho's for $50 a shock. pretty good price for uch an over priced place
Old Jun 22, 2008 | 02:08 PM
Junior000's Avatar
Junior000
Get the ranchos for a 2wd 2500, 2005 and down I guess? Need to make sure I get get it alligned or Ill have to take the 2inch spacers out..
Old Jun 22, 2008 | 02:09 PM
mmstar23's Avatar
mmstar23
what year is your truck man?
