Just took out my middle seat...
Old Jul 9, 2008 | 01:44 AM
pcollins's Avatar
pcollins
Default RE: Just took out my middle seat...
TheUsed,
Not to totally hijack your thread (as I have no advice about the middle console), but how much money was it to get all those blue LED's hooked up in your dash? Those look sick as hell and I wouldnt mind doing that to my truck (I live in AZ so dont worry, no one will know I am copying you ). I dont have a ton to spend, and probably wouldnt go as all out as you, but just a general idea of how you went about getting those in would be great. Thanks man
Old Jul 9, 2008 | 01:46 AM
VOODOO1500's Avatar
VOODOO1500
build you a box out of wood with 4 or 5 in sides wrap it in D plate & mount in where the seat was..
Old Jul 9, 2008 | 01:48 AM
mmstar23's Avatar
mmstar23
diamond plate expensive? HA! i believe i got a 3'x6' sheet of it for $14 and with my employee discount it was less that $10
Old Jul 9, 2008 | 01:55 AM
TraptuR's Avatar
TraptuR
I"m doing the same thing. I took out the center seat because I wanted a center console in its place. I'm currently in the process of finishing up the fabrication. What do ya think?
Cardboard Mock
Mounts where existing seat was.
Old Jul 9, 2008 | 02:08 AM
mmstar23's Avatar
mmstar23
that thing is going to be *&%$# AWESOME!
Old Jul 9, 2008 | 02:20 AM
pcollins's Avatar
pcollins
I agree god damn. You should make those and Ebay em ha
Old Jul 9, 2008 | 08:20 AM
TheUsed801's Avatar
TheUsed801
ORIGINAL: pcollins
TheUsed,
I only have 3 now, I had a lot more before, but the picture in my sig is current. I have two neon tubes, one on the drivers side and passengers side mounted with zip ties, and I put the one in my instrument panel because I had lights burned out. Instrument panel is pretty easy, just go to Auto Zone and get like a 12 inch LED strip, take your cluster out, disassemble it, and stick it in there. Everything's wired up behind the dash to my cigarette lighter/starter button.
Old Jul 9, 2008 | 01:47 PM
05redhemi's Avatar
05redhemi
hey theused you should custom build a huge *** sub box and make it some what into a center console/sub and cover it with diamond plate now that would be killer but then again would defeat the purpose of takin the middle seat out..... dam only if i had the money...and time
Old Jul 9, 2008 | 02:50 PM
pcollins's Avatar
pcollins
ORIGINAL: TheUsed801
ORIGINAL: pcollins
TheUsed,
Cool thanks for the info. I cant tell from your sig, but is that clear tubing with the blue LEDs in it? And I am assuming you didnt do anything to the existing LEDs in the dash circuit board? And finally, did you just splice into the cigarette lighter and feed the wire in from the LED strip?
Thanks
Old Jul 9, 2008 | 02:59 PM
TheUsed801's Avatar
TheUsed801
ORIGINAL: pcollins
Thanks
Nope, I don't have the cigarette lighter anymore. I removed that, and use the power/ground from it to run my starter button and all of my lights. And no, it's not tubing, it's about a 12 inch white LED strip with adhesive on the back of it.
