Tranny and Diff
Old Jul 31, 2008 | 08:48 PM
MeanHemi22's Avatar
MeanHemi22
Default Tranny and Diff
Old Jul 31, 2008 | 09:21 PM
sos's Avatar
sos
Default RE: Tranny and Diff
I have a 2008, so it might be different, but my manual says to "inspect" the transfer case fluid at 30k, and replace the spark plugs. According to my manual, it doesnt need a tranny fluid change until 120k, which seems high.
Old Jul 31, 2008 | 09:22 PM
sos's Avatar
sos
Anti-spin = LSD. Not sure how much fluid, my manual is silent on that as well. A pump will probably help getting the fluid in when you do change it.
Old Jul 31, 2008 | 09:23 PM
sos's Avatar
sos
When you change to synthetic, you still use the same as whatever yourmanual says, probably 5W-30 for your engine, but check your manual.
Old Jul 31, 2008 | 09:27 PM
MikeHTally's Avatar
MikeHTally
His truck is 4x2, so no transfer case. The older trucks need tranny fluid at 30K.
Old Jul 31, 2008 | 09:29 PM
MikeHTally's Avatar
MikeHTally
Rear diff fluid is a bit under three quarts, plus the friction modifier. 5W-30 should be fine for the Denver winter. 0w-30 synth will probably work, as well.
Old Jul 31, 2008 | 09:30 PM
MikeHTally's Avatar
MikeHTally
Spark plugs at 30K, but it can probably wait 'til 50K. Mine didn't get 'em 'til 86K.
Old Jul 31, 2008 | 09:31 PM
MeanHemi22's Avatar
MeanHemi22
Thanks for the info guys. My manual also says to "inspect" the fluids, whatever the hell that means. Also, I found in my manual I need 5w20 oilsince I have the Hemi.
Biggest thing now is when to change the diff fluid and tranny fluid
Old Jul 31, 2008 | 09:34 PM
sos's Avatar
sos
Well it probably wouldnt hurt to change the fluids, especially since you are the second owner. You never know what the old owner did or didnt do. I would think a store like Autozone would know the capacities.
Old Jul 31, 2008 | 09:36 PM
MikeHTally's Avatar
MikeHTally
Tranny fluid is around seven quarts of ATF+4. Rear diff is 75W-140
