Truck wont fire??
Old Aug 26, 2008 | 08:52 PM
02ramATX's Avatar
02ramATX
New Member
Default Truck wont fire??
So i was driving the other day and my truck died... I had a slight over heating before but not during this day.. I was low on gas and refilled with 30 miles to go... I was driving down the road temp just fine, and it stalled at the light.> No biggie.> Started it back up.. Died at the next light.. Thought maybe bad gas.> So i drove on the highway for 8 miles or so and then it died. Temp was ok, oil looks good, all fluids look good and full.. Wouldnt start back up. Doesnt smell like its getting gas but i tried spraying some carb cleaner in there and it still doesnt fire... Motor turns over but it sounds kinda weak.. ANY HELP PLEASE.. thanks Bryan
Old Aug 26, 2008 | 08:56 PM
dazed01's Avatar
dazed01
It needs fuel, fire and compression at the right time to fire. Any codes or check engine light? How are you sure it's getting gas? I'd check to see if you have fuel pressure before going on to anything else.
Old Aug 28, 2008 | 08:12 PM
02ramATX's Avatar
02ramATX
New Member
Default umm
It didnt have any codes.. didnt throw a light and checked it anyways.. DOnt know if its getting fuel. Anway to check minus just replacing the FP.. it turns on when you turn the key but dont smell fuel when i try and pump the pedal... thanks B
Old Aug 28, 2008 | 08:41 PM
dazed01's Avatar
dazed01
Pull a fuel line and put the end in a container, have an assistant crank and see if any fuel comes out.
Old Aug 29, 2008 | 12:10 AM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
if its getting fuel and not firing you should still smell it coming out of the exhaust. need more details on your truck. engine, year, mileage. did you look at the throttle body when you took it apart to see if its real dirty? PCV might need replacing? you said it is really weak turning over, check battery?
Old Aug 30, 2008 | 10:31 AM
02ramATX's Avatar
02ramATX
New Member
Default ummm
So its a 02 ram 1500 4.7.. 99k miles.. The truck stalled at a light.. started up then died while i was on the highway.. It sounded a little rough right before it died but the radio was on so i didnt have time to really hear it.. All the guages were fine right before.. I hooked up a guage at the fuel rail it has 40 lbs. I sprayed carb cleaner in the throttle body to help it start.. Nope. I changed the cam and crank sensor yesterday still the same.> As for the battery its fine.. Just seems like it turns over at 80%. Just seems weak.. ANYTHING ELSE???? Pulled the plugs to do a "spark test" they all spark!
Old Aug 30, 2008 | 12:47 PM
RedSS454's Avatar
RedSS454
Clogged injector? Any of the plugs fouled? What color were they?
Old Aug 30, 2008 | 03:02 PM
dazed01's Avatar
dazed01
Maybe a clogged exhaust, if you have any tools I'd first hook a noid up to the injector wires to see if they are firing. If they flash you are good. If they don't light they are getting no power or no ground from the pcm. If they stay lit the pcm is grounding them constantly which is bad. Unbolt the exhaust before the cat and crank it over again see what happens. If it fires up the cat is probably clogged.
Old Aug 31, 2008 | 07:51 PM
lxman1's Avatar
lxman1
Site Moderator
You have fuel I would check for spark. Perhaps it lost a crank sensor.
