My buddy needs help with his 04 1500
Old Sep 1, 2008 | 01:29 AM
BEAR's Avatar
BEAR
Default My buddy needs help with his 04 1500
Hey guys, I have a buddy that has a 2004 QC 1500 with the 5.7 HEMI, a little while back his ex-wife ran it completely out of gas. He say every since when it gets down to about 1/4 of a tank it starts to shutter on acceleration but he says it only does it at 1/4 and below. Any more than that and it runs fine. The only advice I could give him was NOT TO LET HIS EX DRIVE THE TRUCK ANYMORE!!! I thought maybe yall could help. Thanks
Old Sep 1, 2008 | 02:33 AM
killerbud420's Avatar
killerbud420
It being run so low on gas it might have suck some **** in the fuel filter or hurt the fuel pump im not sure so i would for somebody else to post.. 8 (
Old Sep 1, 2008 | 10:09 AM
05HemiRam1986's Avatar
05HemiRam1986
my previous ram (1994) had the same issue, turned out it was the fuel pump, had the exact same symptoms are your describing.... might be worth looking into
Old Sep 1, 2008 | 10:45 AM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
It could also be the crap at the bottom clogging the fuel filter causing the flow to slow. When the tank is full there is enouh fuel in there where the sloshing around leaves more fuel and less sediment clogging the filter..
Old Sep 1, 2008 | 11:33 AM
BEAR's Avatar
BEAR
So maybe he should try changing the fuel filter first and if that doesn't work check into the fuel pump?
Old Sep 1, 2008 | 11:38 AM
dazed01's Avatar
dazed01
Throw a new fuel pump module on there and call it a day. It's about that time anyway and better to do it on your terms in your driveway then wait till it goes out and you're on the side of the road.
Old Sep 1, 2008 | 11:42 AM
dazed01's Avatar
dazed01
These are like older rams with no external filter right? Just the module in the tank with the pickup pump and filter?
Old Sep 1, 2008 | 11:47 AM
05HemiRam1986
i believe so dazed01, almost positive of it actually.
Old Sep 1, 2008 | 11:58 AM
BEAR's Avatar
BEAR
OK, so yall are saying there is no external filter? He will have to change the pump?
Old Sep 1, 2008 | 12:12 PM
dazed01's Avatar
dazed01
Yessir. Get a dodge one, it's better to pay a little bit more and have it last a while longer. Keep the fuel lever over 1/4 tank the pump will last much longer.
