2006 2wd Lift HELP!!
Old Sep 1, 2008 | 08:43 PM
explorer9950's Avatar
explorer9950
Default 2006 2wd Lift HELP!!
Hey all, Im new to the forum and I think somebody here may finally be able to help me. I have a 2006 2wd ram 1500 with a 2" level kit, and 33" BFG A/T's although it looks great, i want a 3" suspension lift. I can only find ones the are for 2002-2005 Ram 1500 2wd. Will this fit mine or not? Its from Rough Country and is 300 which i can afford, everything else out there is way out of my league at the moment..Somebody please help me!!! Thanks in advance.
Old Sep 1, 2008 | 09:27 PM
HammerZ71's Avatar
HammerZ71
If you do a suspension kit I believe you will have to remove the level kit, (at least this is the case with 4x4's), so you are only going to gain an inch. Add a 3" body lift to your level kit, it's also only in the $300 range...
Old Sep 2, 2008 | 07:53 AM
explorer9950
Really? Alright well ive seen the body lifts, but ive heard bad things about those and I would be putting this on myself, and the body kit looks a bit much for me to do myself...would the 2005 fit my 2006 though??
Old Sep 2, 2008 | 11:19 AM
HammerZ71's Avatar
HammerZ71
I've done three body lifts on my own vehicles and helped three people. Done one suspension on mine and helped do two. Personally I think the body lifts were easier and took less time. PA makes a good kit with great docs and everything you need. I'm not trying to talk you out of a suspension lift, by any means, but any advantages in the suspension kit would be negated by the fact that you have a 4x2, IMO.
But you will have to lose the level kit, as a 4" suspension lift brings up the front 4" but the rear only 2" giving a leveled stance, with the coil spacers in, you'll be 2" higher in the front than the rear. With a body kit, it brings the whole truck up 3", so the level kit is needed to remain level...
Old Sep 2, 2008 | 03:44 PM
explorer9950
ok thanks for the info... I might give the body lift a shot. Does it come with instructions because I'm not to much of an expert when it comes to this kind of stuff. Thanks again
Old Sep 2, 2008 | 05:54 PM
HammerZ71's Avatar
HammerZ71
Go to the DIY section, I've got a PA 3" body lift install DIY there, should still be on the 1st page if not, no farther back then the second page...
Old Sep 2, 2008 | 07:05 PM
explorer9950
thank you sir, I appreciate it...
Old Sep 2, 2008 | 07:13 PM
explorer9950
I cant seem to find it...any help?? I see the DIY forum, but there are only like 5 or 6 threads in there, nothing about lift kits???
Old Sep 2, 2008 | 07:18 PM
explorer9950
nvm that last post, i found it...Im looking into er now... thanks!!
Old Sep 2, 2008 | 08:34 PM
M15's Avatar
M15
Thumbs up
Here check these guys out. http://www.cstsuspension.com/product...6/productID/37 hope this helps.
