anyone heard of this?
Old Sep 2, 2008 | 03:52 PM
tizzle0469's Avatar
tizzle0469
Default anyone heard of this?
ok so you probably know that most all late model rams ( not sure in specific what dates, i know mine is an 07 ) are equipped with a device that will not allow full performance when the gas pedal is floored, i assume it is for keeping the truck from loosing traction under full load...i heard from some hemi guys i know that there is a wire that can be piggy backed or cut that will disable this device....is there any truth to this? if so is there a similar wire for us 4.7 owners and where is it?!?!?!?
Old Sep 2, 2008 | 04:17 PM
lxman1's Avatar
lxman1
Site Moderator
My 08 Hemi does this. It sucks, especially when towing 7500lbs. It pulls harder if you back back out of the throttle about 1/2 way.
Old Sep 2, 2008 | 04:22 PM
Fleisch's Avatar
Fleisch
This is interesting, never heard about this before. Anyone know the way around it for an 07 Hemi?
Old Sep 2, 2008 | 05:43 PM
Hemipwr07's Avatar
Hemipwr07
ya iv never heard of it either
Old Sep 2, 2008 | 06:08 PM
HammerZ71's Avatar
HammerZ71
Yes, I've done the DIY on it, what is preventing it is something called "Torque Management", can only be done with a programmer on your 4.7s and '04 and newer Hemi's. Most "canned tunes" modify this so it's a little better, but you'd need a true "custom tune" to get rid of it completely.
The only exception to the rule is the '03 Hemi, where it is controlled by a separate IC that can be disabled by shorting a wire. Works great, feels like more power than any tuner, but only works for that one year model...
Old Sep 2, 2008 | 06:37 PM
ried69's Avatar
ried69
Where could you go to, to find out how to disconnect that on a 2003?
Old Sep 2, 2008 | 07:34 PM
HammerZ71's Avatar
HammerZ71
I'm not 100% sure if I put it in the DIY or just answered it in a thread, try a search here and in DIY under "torque management" and see if you get any hits. It's been quite a while...
Old Sep 2, 2008 | 11:00 PM
4gun-drill's Avatar
4gun-drill
https://dodgeforum.com/m_354079/tm.htm
Here is the link to what I think that you are looking for. I may try it myself... Just to see!
Old Sep 3, 2008 | 08:33 AM
JRam08's Avatar
JRam08
So does anybody know who does a True Custom Tune for the 08 Rams whit a Hemi.
Old Sep 3, 2008 | 08:39 AM
HammerZ71's Avatar
HammerZ71
'08s are kinda new for custom tunes to be written. I've seen the code that's on a stock PCM, it's like a gazillion lines of code. You can check around at any shops in your area that have a dyno, as they usually either have or have a working relationship with someone that writes custom tunes. But my guess is you'll be waiting a while.
