front differential size???
Old Sep 10, 2008 | 08:13 PM
Romeosoldier03's Avatar
Romeosoldier03
Default front differential size???
chrysler 8" or 8.25??? it's on an 06 1500 4x4....
Old Sep 10, 2008 | 09:43 PM
HammerZ71's Avatar
HammerZ71
Chrysler 8" IFS front differential is found on all Dodge 1500 trucks since '02...
Old Sep 10, 2008 | 09:53 PM
cars01010's Avatar
cars01010
its a C205F front axel on ram 1500,durango/aspen
Old Sep 10, 2008 | 11:54 PM
Romeosoldier03
I know when I bought my gears it was for the IFS truck 8" for 02 and up......I went to the dealer and they said it's a 8.25......I cant find anything now bout a 8"....only 8.25 and 8.375 or sumthing like that.......is it a dana 30?
Old Sep 11, 2008 | 07:34 AM
cars01010's Avatar
cars01010
Front Axle - C205FD
SPECIFICATIONS
AXLE
DESCRIPTION SPECIFICATION
Axle Ratio 3.21,3.55, 3.92
Differential Case Flange Runout 0.076 mm (0.003 in.)
Differential Side Gear Clearance 0 - 0.15 mm (0 - 0.006 in.)
Ring Gear Diameter 205 mm (8.00 in.)
Ring Gear Backlash 0.12 - 0.20 mm (0.005 - 0.008 in.)
Ring Gear Runout 0.12 mm (0.005 in.)
Pinion Torque To Rotate - New Bearings 2.0 - 2.8 N·m (18 - 25 in. lbs.)
Pinion Torque To Rotate - Original Bearings 1 - 2 N·m (10 - 20 in. lbs.)
Fill Level - From Bottom of Fill Hole 6 mm (1/4 in.) ± 6 mm (1/4 in.)
TORQUE
DESCRIPTION N·m Ft. Lbs. In. Lbs.
Mounting Nuts 95 70 -
Differential Fill Hole Plug 34 25 -
Differential Cover Bolts 23 17 -
Bearing Cap Bolts 61 45 -
Ring Gear Bolts 108 80 -
Pinion Nut 271 - 475 200 - 350 -
Electric Actuator 27 20 -
Disconnect Seal 28 21 -
Old Sep 11, 2008 | 10:33 AM
Parts/Service's Avatar
Parts/Service
Some of the confusion may be that Chrysler calls it a corporate 8.25, but it has an 8 inch ring gear...The case has to be bigger than the ring gear so the gear does not hit the case...
Old Jul 13, 2018 | 10:01 PM
salemmerino's Avatar
salemmerino
I have 99 durango rt 5.9 all wheel drive I need front differential 3.93gears
Old Jul 13, 2018 | 10:37 PM
salemmerino
I need 99 Durango rt 3.93 gear front differential any for sale call text me 3302773864
