Turbo on a 1500??
Old Sep 24, 2008 | 02:19 AM
Laramie1997's Avatar
Laramie1997
Default Turbo on a 1500??
Hey I am new to this site, but I was wondering what some of your opinions are. I currently drive a 1997 1500 laramie dodge and I drive the **** out of it and havent had any major problems yet. But the truck is 11 years old and has 130000+ miles on it. So I am thinking about buying a 2008 or 2009 ram 1500. Now, I know that the new hemis put out alot of power, and they get decent fuel mileage, but I want to put a remote mounted turbo on it. Any thoughts? Here is a link to the turbo company's site: ststurbo.com
I just am wondering if the new trucks are put together well enough to handle a turbo charger. This would not be a track truck but a daily driver.
Let me hear your thoughts
thanks,
Chris
Old Sep 24, 2008 | 05:08 AM
RubberFrog's Avatar
RubberFrog
Lot's of guys are running the STS turbo on the hemi. And loving it.
Old Sep 24, 2008 | 12:42 PM
Laramie1997
But are they hard on stock parts? im not looking to have to red the gears or tranny just to make it a reliable daily driver
Old Sep 24, 2008 | 12:44 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
pm kenihemi. he has one on a 3rdgen.
Old Sep 24, 2008 | 01:27 PM
Jeepis's Avatar
Jeepis
Anytime you increase the power greatly over factory levels, it's gonna be harder on parts. From what I can see, the running gear seems to be pretty tough, so if you're not driving it like a 16 year old (brake stands, neutral drops, etc) then my best guess is that you'll be ok. I'd stay on top of maintenance though, keep the trans and diff fluids fresh, since they're the main components that have to deal with that extra power.
Old Sep 24, 2008 | 01:34 PM
Laramie1997
Nah i quit doing that when i had to rebuild the c-clipped rear end in my 1997 1500 (what a pain)
Old Sep 24, 2008 | 02:01 PM
kenihemi's Avatar
kenihemi
The good news:
The STS turbo is the perfect power adder solution to the hemi ram. The extra power is only there if when you want it be. You can drive like normal and the turbo doesn't add any extra power. It only produces boost when you jump on it or add a big load to it, besides just normal driving for most over 40 years old.
The bad news;
The only solid tuning solution for the hemi with forced induction is the SCT Flash Tuner and larger internal injectors, a 2 BAR MAP sensor and an intercooler. As far as I know, SCT does not have a tuner yet that can do the '08 or '09.
That means that you can install the turbo, but you will need to keep the boost down UNDER 3lbs until the tuner is available.
Old Sep 24, 2008 | 02:23 PM
Laramie1997
Ok next question: Does the hemi with the MDS play any part for problems?
