3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I will i am in mississippi with the family for a few days and unfortunately with out my truck but I do have the Commander. As soon as I get back i will take and post pics.
first remove the one bolt on the bottom right part of the pic and then the plastic phillipshead screw on the left. the slide the fuse box toward the engine
first remove the one bolt on the bottom right part of the pic and then the plastic phillipshead screw on the left. then slide the fuse box toward the engine and pull it up. you do not have to disconnect the battery wire as long as the cover stays on.
press on the red tab inside in order to slide the red locking tab up. the locking tab is the one you see here. notice my finger. under it you will find a red tab to depress which locks the locking tab. once tab is unlocked slide it up and press just below the lever which is where my finger is, this will release the lever. you can just put a flat head screw driver under the red locking tab and it will come up really easy but the right way is to depress the tab. Wiggle the harness as you lift the lever to remove the connector from the fuse box.
