HELP!!!! I've lost 2 MPG!!!!
Old Oct 5, 2008 | 12:02 PM
  #21
BEAR's Avatar
BEAR
Originally Posted by Bigbody
alot of the gas companys are using the 10% ethanol now and that does make a huge difference i tried using it since i could use the 87 instead of 89 because of the ethanol in it and i saw a difference of about -3mpg so i would say check the pump and see if thats what you are getting now, I'm from the south so there is no winter gas here so i can't comment on that.
I agree with BIGBODY. My GOAT don't care much for the 10% stuff. I saw the same difference he did running it. I went to the 100% gasoline and got an increase in milage,and this may be in my head but I think my truck runs better on it. And I am also from the south so I can't speak on the Summer/ Winter blend.
Old Oct 5, 2008 | 02:06 PM
  #22
Cappy's Avatar
Cappy
Feeling the drop here aswell and it's the reason I'm checking in. Damn ticking noise got loader too.
Old Oct 5, 2008 | 11:22 PM
  #23
UP_Boilermaker's Avatar
UP_Boilermaker
RVP change in gasoline took effect a few weeks ago here in Detroit. While there may be a loss in MPG due to that, I see a more dramatic loss due to the temp change in the weather. Colder weather = denser air = more tightly packed oxygen molecules = more fuel required to keep the Air/Fuel ratio correct.
Old Oct 6, 2008 | 02:39 AM
  #24
lxman1's Avatar
lxman1
Site Moderator
WOW, fall just started and they are already using the crappy winter blend? That's crazy.
Old Oct 6, 2008 | 07:21 AM
  #25
ivaskaj's Avatar
ivaskaj
3 words... winter blend gas. **** the EPA and those pinko tree hugging *** clowns, they all need to die a slow horrible death.
Old Oct 6, 2008 | 08:26 AM
  #26
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
winter blend is to give you a more volatile fuel so you don't have trouble starting when it's colder outside.
