Oil pressure
Old Oct 15, 2008 | 11:38 AM
deadof_knight's Avatar
deadof_knight
Smile Oil pressure
OK my oil pressure gauge never moves well only time it does move is when I turnit on and off. Anybody have the same thing in everything else I drive it moves so why not in this thing ?
Old Oct 15, 2008 | 04:04 PM
Stunnerguy's Avatar
Stunnerguy
mine does the same thing. Right when I turn it on the needle goes right to the middle and doesnt move. Prob jus a dummy gauge.
Old Oct 15, 2008 | 04:34 PM
deadof_knight
Default this weekend Im putting a mechanical on it to find out
Im going to check it out this weekend
Old Oct 15, 2008 | 05:59 PM
Gone Fishin's Avatar
Gone Fishin
What is the engine size, and are you saying that you have no oil pressure??
Old Oct 16, 2008 | 09:58 AM
lxman1's Avatar
lxman1
Site Moderator
Bad sending unit.
Old Oct 17, 2008 | 12:29 PM
deadof_knight
Wink it works just not like normal
I mean when I turn the key on it is like at zero , then when i crank over the motor and it starts it comes up to straight up , and never moves until i kill the truck ..... more like an idiot light .....
it tells me I have pressure just have no clue whether its 4 lbs or 100 lbs
Old Oct 17, 2008 | 05:53 PM
Gone Fishin
Here's what the FSM says
1. Remove oil pressure sending unit (2) and install
gauge assembly C-3292.
2. Run engine until thermostat opens.
3. Oil Pressure:
²
Curb Idle - 25 kPa (4 psi) minimum
²
3000 rpm - 170 - 758 kPa (25 - 110 psi)
4. If oil pressure is 0 at idle, shut off engine. Check
for a clogged oil pick-up screen or a pressure relief
valve stuck open.
Hope this helps
Old Oct 17, 2008 | 08:12 PM
ryland's Avatar
ryland
I have woundered the same thing. If it was a real gauge it would go down when at idle and up at I think its just a idiot light dressed up like a gauge. It just looks better to have a gauge.
Old Oct 17, 2008 | 08:15 PM
lxman1's Avatar
lxman1
Site Moderator
Mine moves like it should.
Old Oct 17, 2008 | 08:45 PM
ryland's Avatar
ryland
sorry my post sucked, I ment to say be low at idle and go up with your rpm's
