Annoying ding (Door open)
Old Oct 17, 2008 | 07:54 PM
DanTheDodgeDood's Avatar
DanTheDodgeDood
Default Annoying ding (Door open)
Is there a ez way to get rid of the annoying door ding when you have the keys BACK one click (which turns on radio) and a door is open? It just beeps over n over n over n over if my door is open. I want to disable it somehow.
Thanks
Old Oct 17, 2008 | 11:43 PM
HemiLonestar's Avatar
HemiLonestar
I don't think you CAN get rid of that particular noise.
Old Oct 18, 2008 | 12:05 AM
DodgeCowboy's Avatar
DodgeCowboy
yeah i want to do the same thing with the seat belt ding. i do a lot of driving on our ranch and i don't feel like putting it on all the time. if you find any thing let me I'll do the same.
Old Oct 18, 2008 | 12:44 AM
lxman1's Avatar
lxman1
Site Moderator
Leave the belt buckled up behind you and no ding.
As for the door, leave the window down and the slider open if you want to listen to the stereo. I can't see any other reason to leave it open. Or you could open the passenger side instead.
Old Oct 18, 2008 | 01:05 AM
z3r0's Avatar
z3r0
http://www.*********.com/forums/showthread.php?t=179994
idk if i can post links to other forums or not but ...
its talk
Old Oct 18, 2008 | 01:41 AM
jstmahoney's Avatar
jstmahoney
There is a thing in the owner's manual about the seat belt chime thing. to disable or enable it. As far as the door open ding, you would have to make the sensor on the driver door think that it is closed. How? IDK!? If you think that's annoying, Do any of you guys know what the sound was for the 2nd gen rams? ANNOYING!
Old Oct 18, 2008 | 01:54 AM
z3r0's Avatar
z3r0
how about late 90's gm it was either too quiet of deafening
Old Oct 18, 2008 | 02:53 AM
Laramie1997's Avatar
Laramie1997
on my 1997 I just looked around until i found the soruce of the noise, and then just cut the wires going to it. Had a buddy with the same truck that hated it too, got pissed at it one day an jabbed a screwdriver thru it. It worked.....
Old Oct 18, 2008 | 10:37 AM
epegasus's Avatar
epegasus
Cute. Knowing my luck the 02s probably have that sensor tied to the ECU that detects crashes. Jabbing it with a screw driver would probably cause the airbags to deploy 8-0.
Old Oct 18, 2008 | 10:51 AM
squatchie16's Avatar
squatchie16
I wouldnt mind knowing how to disable that myself....its annyoing when you want to listen to the radio and the stupid ding keeps going off
