Tpms
on
I have the same issue on my Grand Cherokee. My current tires are rated for more air than stock. On a vacation this summer I inflated my tires to 38 psi cold (rated max is 44) instead of my normal 34 psi to get better mileage on the highway. On sustained highway driving in 95 degree heat my tires got a lb or two over the 44 psi where the overhead kept buzzing and annoyed the hell out of me. I finally dropped the tires to 36 psi cold where they stayed just below the magic 44 psi hot.
It's a royal PIA that you cannot adjust or disable it. Luckily my truck (an '04) does not have it bacause I'd get hit with a double whammy. My FCII's have a max of 50 lbs. plus I often air 'em way down to play on the sand or in the mud...
It should be fine just as long as the shop fills the tires within the sensors specs..cause our trucks just recognize a problem with a warning light.. the light will be on when you get your truck back most likely but should go off after like 10 mins or normal driving.. when youstart getting into sensors that show you each individual tires pressure on a display unit and all that then they'll have to get the system to relearn the sensors.. but that only takes like 20 mins
