cb radio
Old Nov 18, 2008 | 12:17 AM
irelandshemi's Avatar
irelandshemi
Default cb radio
where did you guys hook up the power wire?
thanks in advance
Old Nov 18, 2008 | 01:29 AM
bananafarmer's Avatar
bananafarmer
hook the power wires directly to the battery for the best results. this will help to keep the stray rf waves from damaging your main computer.
Old Nov 18, 2008 | 02:04 AM
irelandshemi
it only came with around 3ft of wire so i was hoping to get an alternative hookup point so i didnt have to splice wires together to make them longer, is it that much worse is i hook it to like the ciggarette lighter or anything like that
Old Nov 18, 2008 | 07:21 AM
RubberFrog's Avatar
RubberFrog
Tap into your cig lighter. "Stray rf waves" will not hurt your pcm. lol
Old Nov 18, 2008 | 09:21 AM
ramhunter9's Avatar
ramhunter9
i tapped into my radio wires. i used the ignition wire for power just in cace i forgot to shut the cb off. this way i know if the truck is off everything is off.
Old Nov 18, 2008 | 11:30 AM
Hemipwr07's Avatar
Hemipwr07
i hot wired mine into the power seat..works great and dont have to have the truck on to use it
Old Nov 18, 2008 | 12:23 PM
irelandshemi
i might look into the radio wires, cuase i have a tendency to forget to turn things off
Old Nov 18, 2008 | 01:49 PM
KC9JVC's Avatar
KC9JVC
The big problem with not hooking it to the battery is you'll pick up alternator noise, especially if you use the cigarette port.
Old Nov 18, 2008 | 02:42 PM
KKYW Ram 7's Avatar
KKYW Ram 7
I went to radio shack and brought a plug for the ciggarete adapter and then plugged the wires into that. Works perfect and it shuts off when the truck shuts off.. No ground issues or noise.
Old Nov 18, 2008 | 02:50 PM
irelandshemi
a plug for the ciggarette adaptor? like you just wire it to something that plugs right into the lighter?
