hella 500s
Old Dec 8, 2008 | 08:18 PM
  #21
nickahern1's Avatar
nickahern1
yeah ill try that.. thanks
Old Dec 9, 2008 | 03:55 PM
  #22
red06RAM's Avatar
red06RAM
I saw you got it changed. So welcome back NICK.
Old Dec 9, 2008 | 04:07 PM
  #23
nickahern1's Avatar
nickahern1
yeah i figured i would choose something more appropriate. now my name can be quoted without stars........
Old Dec 9, 2008 | 04:31 PM
  #24
TRXHemi's Avatar
TRXHemi
Did you have to PM someone? Mine is kind of stupid and has zero relevance....
Old Dec 9, 2008 | 06:40 PM
  #25
nickahern1's Avatar
nickahern1
yeah pm 94rt10ohio and he will help you out . he is one of the moderators of the site.... how you liking the hellas compared to your old lights???
Old Dec 9, 2008 | 07:42 PM
  #26
02Steve1990's Avatar
02Steve1990
How exactly did you guys get the power to the Hella 500's, and can you still use your fog lights too? I may be interested in picking up a pair from Walmart if that's where they you can purchase them. Also, can you use the Hella 500's with your headlights and fog lights on?
Old Dec 9, 2008 | 07:54 PM
  #27
nickahern1's Avatar
nickahern1
yeah... there is great directions that come with the lights. you wire the relay to the battery,ground,switch,lights and then from the switch to a 12v power source,ground ( kit tells you to choose hibeam signal which means the hella's will only come on with the hibeams) i tapped into the parking lights so anytime the parking light are on the hellas will go on ( i have the option to turn them off manually too) some guys tap into a 12v source that comes on anytime the key is in the on position. its all preference. and walmart usually sells them for $45-$55....... if you need help post it here and we can help you but its pretty easy
Old Dec 9, 2008 | 08:31 PM
  #28
02Steve1990
Alright I'll probably pick some up sometime this week or next and give it a shot, if anything comes up ill definitely put a post up, thanks for the help.
Old Dec 9, 2008 | 09:32 PM
  #29
Ridinhigh's Avatar
Ridinhigh
now are the hella's from walmart only driving lights or do they sell the pencil beams at walmart and how much would they run becaue if they are still 55 bucks then i have my next project for christmas break and i know i will be putting a set of these in plus my sound system and getting the windows tinted and a torsion lift since i will have a lot of time to work on it and i will post some picutres of them all
Old Dec 9, 2008 | 09:40 PM
  #30
nickahern1's Avatar
nickahern1
well the hella 500s are advertised as driving lights but they have a very focused beam (i think that is what you mean by pencil beam) They arent very widespread but they still look very good and add alot of light even over the hibeams....
