Looking for lift advice
Old Dec 14, 2008 | 11:39 PM
xoktoberskylinex's Avatar
xoktoberskylinex
Default Looking for lift advice
I just got a 2004 1500 LB and I wanted to put a 3" lift on it. I was looking for some info on where I should buy the lift kit from and any input or thoughts about it.
Old Dec 15, 2008 | 09:35 AM
stupid_rope's Avatar
stupid_rope
First off, what application type are you looking for? Do you just want the look or do you want it to work well off road? Whats your budget?
Old Dec 16, 2008 | 11:46 PM
xoktoberskylinex
I want it to have a lift that will work off road, I was thinking maybe only like 3 inches or so. My budget right now isn't that great, I'm only an E-3, but I wanted to get an idea of what to set my goal at for saving money to.
Old Dec 16, 2008 | 11:50 PM
HammerZ71's Avatar
HammerZ71
For off-road performance, look at a suspension lift if you can afford it. I've had 3 trucks that I put 3" body lifts on before putting a 4" suspension lift on my current ride. No comparison on the quality of ride and articulation off-road.
Old Dec 16, 2008 | 11:59 PM
xoktoberskylinex
so a 4" suspension lift is better? do they make one smaller size, like a 2"? Because I don't want to jack it to much, just a little.
Old Dec 17, 2008 | 12:01 AM
HammerZ71's Avatar
HammerZ71
Then just crank the torsion bars, it'll give you the 2" you want, keep stock suspension specs and best of all -- it's free!!!
Old Dec 17, 2008 | 12:02 AM
TheBaker's Avatar
TheBaker
You can get a leveling kit, lift the front 2''. Or a 3'' lift, lifting the front 3'' and rear 1''.
xoktoberskylinex
ok, since I'm new to all this, where can I find how to do that?
Old Dec 17, 2008 | 12:03 AM
TheBaker's Avatar
TheBaker
Sorry i worded that a little wierd, the leveling kit would add 2'' inches to the front, thus leveling it.
Old Dec 17, 2008 | 12:04 AM
TheBaker's Avatar
TheBaker
search the forums on "leveling kit" there a few DIY forums on that. Not a too hard install, I didn't want to mess with it so I payed a local shop $150 to do mine. Just be sure to get tires aligned after. The leveling kit is only a spacer usually sitting atop the coil spring, cost me 40$ for parts. If you have a 4wd they run about $70 for 2.5'' leveling kit.
