lamp out light..any suggestions?
Old Dec 20, 2008 | 11:02 AM
froto'sride's Avatar
froto'sride
Default lamp out light..any suggestions?
So a while ago while I was in Nashville,tn my lampout light can on. Now i know that is should mean that an exterior light or fuse for one of those lights are out. however I have checked all of those things and none of them are out to include my blinkers. The only thing that I know is out is my drivers side door accutuator. Could that make the light come and stay on/
Old Dec 20, 2008 | 11:30 AM
dodge it then ram it's Avatar
Did you test your brake lights? Same thing happened to me with the brake light. Have someone step on it while you check. If not that, then your guess is as good as mine.
Old Dec 20, 2008 | 03:08 PM
bananafarmer's Avatar
bananafarmer
mine did that but it seems that the light came on about a week before my light actually went out and both times it was one of my brake lights so just keep watching it and you might just be surprised.
Old Dec 20, 2008 | 04:53 PM
froto'sride
That's crazy that it came on way before they went out. mine has been on for about 2-3months now. I guess that I will just check them all again and again until one goes out.
Old Dec 20, 2008 | 06:20 PM
SmokeySportRam's Avatar
SmokeySportRam
all lights to check-
Headlight high and low beams,
Front turn signals
Front marker/parking lights
Fog lights
Rear marker/parking lights
Rear brake lights
Rear highmount brake light (on the cab)
Rear turn signals
Lic plate lights
and
cargo lights
that should be about everything to check, good luck
Old Dec 20, 2008 | 06:23 PM
lxman1's Avatar
lxman1
Site Moderator
I have also heard of the light bar in the trail lights causing problems with internal bad connections on the 06-back with the 3 bulb system. 07 and 08 only have 2 bulbs, one tail/brake and 1 back-up.
Old Dec 20, 2008 | 09:53 PM
rabbripper's Avatar
rabbripper
Default 02 dodge ram 1500
I turn my truck oof and the front and rear running lights stay on. when i turn my truck on the abs and the parking light guages stay on for 1 minute then go out. then every once in a while i hit my brakes and the check lights comes on the off when i let go of the brake. only resolution i have found so far is too remove ground from battery when i am at home. need any suggestions
Old Dec 20, 2008 | 11:20 PM
SmokeySportRam
you got a big wiring problem or a bad ECU.
take it in to the dealership
Old Dec 21, 2008 | 10:50 AM
talon6's Avatar
talon6
so true, i had that problem. took me awhile to figure it out. replaced both tail light boards,and all problems fixed. like 20$ each from the stealership.
Old Dec 21, 2008 | 11:21 AM
froto'sride
when you have this problem next try looking for codes. If you do not know how to do that just turn your key three timesall the way forward with out starting it and all the way back. if there are any codes they normally show up. however i am not sure if this feature is on the '02 models. most likely it is your ECU considering all of the problems they have had with this paticular year model.
