worse MPG with new EGR
Old Dec 21, 2008 | 03:21 AM
ih8myv8's Avatar
ih8myv8
Default worse MPG with new EGR
a while ago my CEL came on, pulled the code and it was the EGR. before i replaced it i was getting 10.2-10.8 city only with the overhead calculator. it ran rough and would stall out. i changed it, CEL went away after i cleared it and it runs smooth but now it get anywhere from 9.3-9.7. i have yet to manually calculate it since i replaced it but when i did with the bad EGR it was within a few tenths from what the overhead was reading. its a 2005 5.7 hemi bone stock with 40k miles. any ideas?
Old Dec 21, 2008 | 08:36 AM
kincer04hemi's Avatar
kincer04hemi
You should reset the pcm. Pull fuse #23 get into truck, turn key to the start position after a few seconds you will hear a chime that means the pcm is reset, replace fuse and your are done. That should help also it could be winter gas.
Old Dec 21, 2008 | 02:48 PM
ih8myv8's Avatar
ih8myv8
ok thanks, ill try that. does that mean the computer is still reading theres a bad egr even though the CEL is off? im not sure if its winter gas because i live in CA and it never gets below 35 where im at
Old Dec 21, 2008 | 03:01 PM
kincer04hemi
You should do that anytime you do a mod that would affect the drivetrain and that includes maintenance. The pcm would eventually relearn that you changed the egr but it takes time.
Old Dec 21, 2008 | 10:08 PM
froto'sride's Avatar
froto'sride
Random thought...is that the same "secret way that some guy at the shop wants to charge me $62 an hour to do?
Old Dec 21, 2008 | 11:07 PM
lxman1's Avatar
lxman1
Site Moderator
Probably.
