3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
How would you wire them if you just wanted them to turn on when the trucks in reverse? Would you just use the power wire going into the reverse light and use a random ground anywhere? Or would that be too much to pull from that one wire?
the proper way would be to run the main power to the lights with on a seperate wire with a relay turning that power on via the stock reverse light wire as the on for the relay.
